Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
LCD tv issue
My TV will not power on, the red led flashes 1 long pause 2 short. Do you know what this error code means?
Where can I find a repair manual. Any help would be greatly appreciated.
Thanks
  • 138 Answers
At error code is 12 and it is your 12-volt supply. Measure from the inverter to the power supply for 24 volts pins 1,2 and 3. If you don't have the 24 volts disconnect the inverters from the power supply and see if the volts come up. If the 24 volts come up replace the inverters. If the 24 volts are still not there replace the power supply. The volts have to be steady and not going up and down if they are replace the power supply.
But if the 24 volts are there with the inverters connected 1M03 pin 3 for 3.2 volts. If the 3.2 volts are not there replace the small signal board. The only way to get a manual is to find it on line or call the manufacture.
Posted on Aug 26, 2008
What do two long and 5 short white blinks mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 21, 2015 | Sharp LC 70LE640U AQUOS 70 1080p LED LCD...
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,jimvincentvillanueva@yahoo.com
Mar 07, 2012 | Mitsubishi WS-55313 55" Rear Projection...
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Sony Bravia KDL-40V300 won't turn on.
Unfortunately 5 blinks is a LCD panel error. The only way to fix it is to replace the whole LCD panel. This is the most expensive part in the TV.
part number: 1-802-488-12
List price: $1336.32
Core charge: 1790.00
You could try to replace it yourself but would need to take the whole TV apart by first taking off the back cover, then removing all the boards in order to get to the panel before putting it back together but I would just recommend buying a new TV as the price of the repair exceeds the price of a new TV of the same size.
Oct 13, 2009 | Televison & Video
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
My tv willnot turn on
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
356 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
