Question about Sony KP-57WS500 57" Rear Projection Television
Dead set When the power button is pressed the internal relay clicks and the power light comes and stays on, then another is heard but the power remains on. The set remains dead otherwise no raster no audio.
  • Sony Master
  • 5,138 Answers
BAD FBT Flyback transfomer.
Posted on Sep 04, 2008
Poineer deck amplifier dc-z74 relays click but set deck does not come on no display lights dead unit
Part of your PowerSupply is Frito.
Probably the +/- 15 volt rails, could be other.
Check inside power voltages, probably some regulators are gone.
Preferably get a tech unless you have the know-how and test equipment...
PEACE---
Feb 09, 2016 | Audio Players & Recorders
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Dead
Better to pull up the error codes. Following areas can also be checked:
1. Fuel pump control circuit
2. Electronic throttle control system
3. Immobilizer
4. Crankshaft position sensor circuit
5. Short circuit.
7. ECM.
Feb 27, 2014 | Toyota Prius Cars & Trucks
My toyota sienna 2001 was opening by remot control now it is not working roof light not working warnnig
hello
Prius2 is not powering up after one person swapped ower polarityof battery while changing it. We changed Big fuse at the front of the car and couple of small fuses. Now when pressing power button we have engine light and power button orange light fore just one sec. After it just stays dead. While pressing power button you can hear couple relays clicking for a sec and dc to dc giving hi frequency noise for the same amount of time. Help us please. This prius was manufactured in 2003. Many Thanks
Feb 27, 2014 | 2001 Toyota Sienna
I reversed polarity on my jumper cables and blew the main fuse on my 2010 main fuse...what do I need to do?
hello
Sep 29, 2012 | Toyota Prius Cars & Trucks
Hp pavilion ze1210 intermittently boots up or will not turn on at all.
ok it's a laptop., old.
let me guess 2003 made, square 4:5 screen
XP removed, (smart idea) Linux installed.
I guess the screen is 100% dead, not one pixel ever glows, right?
no text, ,no BIOS screens on demand, (esc key pressed, power on)
1: step 1 is always remove the main big battery. run now?
2: try external VGA screen yet, to see if the old internal screen is dead? see that VGA jack on the rear, and the hot function key that turns it on, bingo.?
(use a flash light to see if screen internal has data but the
CCFL back lamp is dead.?)
4: if bios is dead and both screens fail,what is next.?
19vdc from the power pack must reach the guts (MOBO)
if not all HP lap tops die. use a voltmeter or get a spare power pack
many power packs this old are now bad. 14 years old,
the can be good, bad, or weak. weak is bad.
5: sparks is a bad thing, in all cases, when heard it needs service.
BSOD:
http://pcdied.com/#black-screens
May 04, 2017 | HP Pavilion ze1210 Notebook
Motorcycle Mechanic Advice on a 1992 Heritage softail. Having ignition problems. Lights come on and I get a clicking in the starter relay, but when I switch it to ignition, there it is completly dead....
I'm a little confused. You said that the lights come on and you get a clicking at the starter relay. Then you say that when you switch to igniton, everything goes dead. From the factory, you must first turn the switch to the ignition position before you can get anything, lights, starter, horn. Some guys set their switches up to be like an old style bike. First click is ignition, second click is ignition and lights. But, since most states now require you ride with your headlight on all the time, Harley simply wires the switch to a "one position" switch.
At first guess, I'd think you have a bad switch because you said the when you went to the "ignition" position, everything went dead.
But, you said that you could get lights and a clicking noise. If the clicking is coming from the small one inch plastic cube starter relay, you may or may not be getting power to the starter solenoid.
Look at the starter from the right side of the bike and you'll see a five sided plate with three small bolts holding on. At the top of this plate, you'll see a single wire connector. Unplug this wire and use either a test light or a volt meter to test for voltage on this wire when you press the start button and the starter relay clicks. If you do, the relay is good but something is wrong in the starter. If no voltage, the relay is not doing it's job.
Good Luck
Steve
Aug 27, 2010 | Harley Davidson FLSTC - FLSTCI Heritage...
Dryer does not start up when the start button is pressed. It makes a click like a relay is closing but no power to the drum motor, or electric heat. unit interior lights up, and controls light up. When...
Your belt is likely broken. Pop the top (held down by spring clips) to inspect. If you see it - try to lift it. If you can not lift it it is ok. If not ok, remove the front cover for complete access to the drive.
Dec 29, 2009 | Kenmore HE2 Plus Front Load Washer
Dead set
These sets had a serious crt problem.Check and see if there is any arching on the tubes or tube sockets.
Mar 07, 2008 | Samsung HC-P4752W 47" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
