Question about Kenmore 62602 Electric Dryer
Kenmore model 62622
When I set the timer and hit the start button I either get a buzzing sound or the motor wants to go, but it will keep going. I opened the front door held down the switch to the door and it did the same thing. Could it be the start button?
  • 639 Answers
Peace Friend,
ngfam1 At your service!
Sounds like it may just be the start button!
Good call!
Want a good parts company that is usually next day delivery if it's in stock?
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunately, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Posted on Sep 02, 2008
Kenmore dryer problem
Good day,
Sounds very much like the motor is going bad. Very slim chance that the timer could cause that problem because of pitted contacts, but that would not explain away the noise when trying to start.
Here's a good tutorial if you want to replace the motor.
http://www.applianceaid.com/wpmotor-change.html
Apr 01, 2010 | Kenmore Dryers
When I set the timer, the heat element comes on before I press the start button.
The element is actually grounding out through the timer. Time for a new timer.
Dec 08, 2009 | Kenmore 62622 Electric Dryer
When I push the start button a buzz sounds and the
sounds as if the motor is not starting,try to turn tumbler manually.if tumbler turns but motor does'nt start check motor.
Oct 16, 2009 | Dryers
Kenmore dryer doesn't start at all.
The start relay is the first place to look. It will be difficult to check components without a meter to check voltage.
Aug 01, 2009 | Dryers
Gas dryer wont run
Hi. there can be many issue that can cause this type of interruption in normal operations. Lets go threw a few.One could be a faulty or dead motor. The timer board sends a signal to the motor once the start button is pushed. If the motor is malfunctioning or the wires that connect to the motor are lose or old and worn, the motor will usually click or buzz. the fault itself can be within the timer assembly or the motor itself. the best way to find out is to test the current flow at the motor by using a multimeter. connect this meter to the motor terminals and select the cycle and hit the start button. if the meter reads voltage at the motor and the motor clicks or buzzes, this will confirm an actual motor failure. if the voltage at the motor is weak or not there 0, this means the timer will need to be replaced. Next, I would check the door switch for its operational value. you can use the same method as i discussed above with the meter. use the terminals for testing on the switch. This could be a problem area as well. if the switch is malfunctioning, the dryer will not run at all. you will find the problem in one or both of the discussed areas above.
please rate and god bless.
Mar 25, 2009 | Kenmore Dryers
Kenmore microwave making loud buzzing sound.
Mar 05, 2009 | Kenmore 62622 Microwave Oven
Start button on microwave does not work
Some numbers are missing off that model number. Would that be model 721.62622200?
(If not, please reply back with the correct model number off the tag)
If it's cooking with the programmed buttons, but Start is not working, it sounds like the keypad has failed.
The keypad for model number 721.62622200 is no longer available as a separate part.
So you'd have to buy the entire controller assembly, which includes the plastic frame, keypad, and circuit board, etc.
It is part # 4781W1M307A and it runs $110.10 at the Sears parts Web site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Kenmore 62622 Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Kenmore 62602 Electric Dryer Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
