Question about Kitchen Ranges
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will light what little gas that comes to the burner. Walt (
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Posted on Jan 12, 2009
My gas oven (Frigidaire Gallery) is not preheating or coming up to temperature. The broiler and stove top burners work fine.
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
Jul 18, 2011 | Frigidaire Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
My Maytag Gemini Gas Range works fine as far as the four burners, the bake on the top and bottom oven, but the broiler on the top oven does not work. Is this a pilot issue? I really appreciate the help,...
If the broiler burner is not coming on it may be a bad ignitor or the ignitor may not be getting power. Observe the ignitor when you turn in on ans see if it glows at all. If not then test for power to the ignitor if you have power and not glowing or lighting replace the ignitor. If it glows but does not light the ignitor may just be weak replace it.
Nov 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My stove will not heat using bake but will work for broiler so I know it is not a heating problem. Help!
this model is not a dual fuel, and you do have a heating problem, there are two burners, a bake burner and a broil burner, both have ignitors. You have a bad bake ignitor.
Sep 27, 2009 | Maytag MGR5775QDS Dual Fuel (Electric and...
Oven burner won't light
You likely have a bad ignitor. It's like a mini element that heats up and then ignites the gas once the valve releases it. When the ignitor gets old it doesn't glow bight enough or draw enough amperage so the gas valve won't open. If you set bake and see a glow coming from under the plate in the oven but the burner never lights that's your culprit. They probably cost about $50-$80. Good luck!
Apr 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
the gas valve has gone bad change the gas valve and the glow bar (igniter) at the same time.or you WILL have problems in the future
Dec 17, 2007 | Maytag MGR5750 Gas Kitchen Range
Kitchen Ranges Logo
401 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
