Question about Singer CE-100 Futura Computerized Sewing Machine
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on the sewing machine. So everything is sewed out as if it was on a large hoop.
It was 27/08!!
Posted on Oct 04, 2008
Follow the steps that the futura website recommends in their FAQ. (Turn on machine, attach small hoop, and then start Futura software and make sure small hoop is recognized on the computer.) If this is a design that you have modified in any way (ie- added font, or merged designs, etc...) or a design that you have created your self you need to REDO and resave the design on the small hoop now that the computer is recognizing it. I had a name drop design and I added the name and saved it- all in the large hoop and had the same error message although I followed the steps for recognizing the small hoop and it seemed to work until I actually started embroidering. When I redid the design under the small hoop, it worked fine!
Posted on Sep 27, 2008
  • 64 Answers
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Posted on Aug 26, 2008
  • SheTiger Sep 27, 2008
    Guest's advice from 27/09 is wrong regarding necessity to redo design, reopening of the existing design or saving and reopening of just created design will be enough.
Lights blinking on singer futura
The most likely cause of this is the needle is not ALL the way up, although it may look like it is. The CE machines are VERY sensitive to the needle position. The second cause is putting on the small hoop and turning on the machine; with the small hoop on, it cannot set to its default position. If you want to use the small hoop, leave all hoops off, then put in on AFTER you have turned on the machine.
Jan 19, 2014 | Singer CE-200 Quantum Futura Computerized...
I'm having problems with my singer futura quartet seqs-6000. While embroidering the machine begins to stich but the hoop does not move so all the thread gets caught under it in the bobbin. how do I f
for the hoop, you could turn off the machine and restart, or put in the big hoop and then select the small hoop for ur design. and get some TCL on all the bumps by joining the future group on FB. and don't forget to "pay it forward" back here on this site.
Nov 16, 2013 | Singer Sewing Machines
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
My Singer Futura keeps telling me that I have installed the small hoop and need to change it to the large hoop...but I have actually installed the large hoop. It is giving me an incorrect error message. I...
Make sure you have the latest software version. Current version you may check in About dialog under Help submenu and in the same submenu you wil find a function Live Update.
Also make sure you switch on the sewing machine either with the large hoop connected or without hoop. If sewing machine was switched on with the small hoop attached, it will provide this error message about wrong hoop.
Jan 30, 2010 | Singer CE-200 Quantum Futura Computerized...
My embroidery unit does not recognize my hoop size. I am using the 240 x 150 and I have the size selector set to the size. When I try to start my project the screen says to attach correct hoop size. I...
The first thing to check is the software version on your machine. Later versions are far better at recognizing the proper hoop than the earlier versions. The current version is 2.24 . Check this by looking at the bottom, right corner of the welcome screen when the machine is first turned on. The numbers in that corner are your software version.
If you are in the 2's, then adding the latest probably won't change this problem. Make sure that when the hoop is slid into position you do not go beyond the proper position. The release button on the hoop holder should drop down fully. If it is slightly raised, pull the hoop back toward you, without holding down on the button and see if it clicks down farther. If so, I recommend that you press the button just when you start the hoop onto the machine, then release it and as the hoop slides back it will click into the hole. Wiggle the hoop a little and the button should seat fully and then the machine should recognize it. If it still does not recognize the hoop, you may need professional attention.
Apr 08, 2009 | Husqvarna Designer I
Hoops
i found both hoops on this websit.....thesewingcenter.com...lrg...13.99, sm...12.99!!!!! it took me 2 months of web seaching to find tem
Jan 15, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Futura CE 150 not recognizing small hoop
Except advices from the previous posts I suggest to check out whether you install small hoop precisely, there should not be any deflections, you need to insert it on the full length and fix it very well.
Sep 06, 2008 | Singer CE-100 Futura Computerized Sewing...
Problem with small hoop
Uninstall your Futura software and reinstall.
Dec 19, 2006 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
216 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
