Question about Sony NWZ-S615F Walkman Video MP3 Player
It was in the washer for a minute now it wont work
It was in washer just the cycle where it put water in it for like 30 seconds to a minute . i dried it off and i tried to charge it after hit buttons repetaedly . it didnt do anything but i pull charger out and water is on it so is it still possibly going to work
It might have been fine if you had left it alone to dry for a couple of days before turning it on or charging it. Hopefully it works now man.
Posted on Sep 02, 2008
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
How do i know if machine is condensing the water properly
Simple. When in the Drying Cycle, does the water pump turn on and pump out a 4-8 ounces of water - about every 4-5 minutes?
To check, pull the drain hose out of the wall (drain pipe) and hold it a few inches above the drain pipe, so you will be able to see when water comes out. Typically, the pump turns on for about 30 seconds every 4-5 minutes.
It is important that the cold water is turned on, and is available all through the drying cycle, because a light spray is constantly used to cool the internal condenser.
I'm assuming the Dryer is getting hot. If not, see previous posts about the Heating Element and Working Thermostat.
I'm also assuming the little blower fan is working. It's at the very top, slightly to the back right. It should be on continuously, during drying.
Remove top (2 torx screws at rear) to observe.
May 26, 2014 | Malber WD1000 Front Load Washer/Dryer
Aquaglass whirlpool tub
Does you tub have the air system installed? If so you may have the air system advanced function. There are two types of air system advanced functions.
  1. With water level detector: A 30 second Drying cycle Will automatically start 20 minutes after the control has detected there is no more water remaining in the tub.
  2. With out water level detector: A 30 second Drying cycle Will automatically start 20 minutes after the complete stop of the blower.
If you have the first type this may be normal or the water level sensor may be dirty or faulty.
If you have the second type it may be a control board problem.
. Hope this helps.
Jan 12, 2014 | Home
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
Jun 11, 2009 | Haier HWD1000
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Sony NWZ-S615F Walkman Video MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
