Question about Vizio L32 32 in. LCD HDTV
Black screen on vizio
This tv just went into a black screen in the middle of a movie. The power button is the only thing that works does anyone have an idea of what might be wrong. I read somewhere about z and y boards not sure if i should dive in and purchase these parts.
  • 5 more comments
  • dodong1 Aug 31, 2008
    the screen went blank, however the sounds is still on
  • dmm7 Sep 10, 2008
    Same thing happened to me! I had the tv going for 7+ hours and then all of the sudden it just turned off... sound is still on though. I turned off the tv and let it sit for a minute, and turned it back on. The picture stayed on for like 5 seconds, then turned black. I JUST BOUGHT MY TV 5 DAYS AGO! And this is the first time I used it for 7 hours! What's the deal?
  • Anonymous Oct 06, 2008
    sound but no picture!! and i just threw my recipt out cuz i figured it was working so well for so long.. vizio is no help either! how can i fix it??
  • craig_riggs Nov 16, 2008
    only the power button works...literally nothing else is functioning
  • warddog Nov 18, 2008
    i have the same problem but with a 42'' .was wondering if you got it fixed?
  • Anonymous Nov 24, 2008
    I have the same problem. was watching a movie and picture went blank but i still have audio
  • okiepainter Dec 07, 2008
    I have a vizio 42 inch a year old and the screen just went black
It may be the inverter part.
Posted on Aug 30, 2008
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
My Vizio LCD TV went out. Its just a black screen. The Vizio symbol turns on and off but no picture and no sound. It sounds like its similar to most peoples issues on here. How do I know if its my mai
There could be a few things that would cause this. I would suspect that you have a problem with either the power supply board or the main board. Based on my experience, the main boards go before the power supplies. What is the model #
Jan 26, 2013 | Vizio E550VA 55 in. LCD TV
Vizio screen problem
type in troubleshotting and the model number and the problem and see what you come up with these are searches
Jun 03, 2012 | Vizio XVT3D554SV 55 Full Array LED Full HD...
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
May 30, 2009 | Vizio GV47LF Television
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
850 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
