Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore model 59675502400
We have a Kenmore bottom mount refrigerator. The freezer is cold but not the refrigerator. The compressor was check and fan motor replaced but it still doesn't work. We did the diagnostic test to make sure the damper was open and that was ok. We think the problem is that what ever controls the fan motor isn't turning the fan motor on. Can you tell us what to check?
  • 2 more comments
  • carawan_crew Aug 26, 2008
    The fan motor on the inside of the unit was replaced.
  • 22blaze May 18, 2009
    I have this same issue. Freezer is good, fridge is warm.
    I replaced the freezer fan motor, still not working.
    What can I check next?
  • francis rivero May 11, 2010
    when you open the evaporator, is it clogged with ice?
    you have two fan motors, one inside the evaporator and one outside in the condenser near the compressor. which fan motor was replaced?
  • 958 Answers
If the evaporator is clogged with ice, then you have a defrost problem.
check the defrost heater and the bi-metal .
to answer your question what controls the fan then it is the module that controls the fan.
you said you have diagnostic to test the damper then there should be a procedure also to test the evaporator fan motor.
why don't you try it..
tnx 4 using fixya,
Posted on Aug 26, 2008
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
My kenmore fridge with bottom freezer, model#596.785.83801. Both fridge and freezer won't stay cold. Fan on and lights are on. Help!!
Check to see if the compressor in back is running. It could need a new compressor start device. If it is running it could need a new compressor. The compressor cooling fan could be stalled and the compressor is overheating.
Sep 26, 2014 | Refrigerators
Fan was running but neither fridge or freezer were getting cold. You could hear the compressor attempt to start every so often. We replaced the capacitor and the relay and the unit cooled down. The...
Have you checked the thermal overload on the compressor.It should be mounted on the side of the compressor to feel the heat and shut it down if need be.
Usually a disc type.
Jun 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Have Kenmore 106.8607913, top freezer. Not cold enough. All fans working. Cleaned bottom coils. Not ice bound. Compressor clicks on, then off about 1 or 2 seconds later. Compressor or thermostat,...
If the fans continue to run when the compressor kicks off the thermostat is functioning normal.
The problem could either be the compressor itself or more likely the start device (relay) that controls the compressor, it is an easy component to replace and mounts directly to the compressor.
The part number for the relay is 989662
If the relay is good and compressor is bad, you would be looking at about $500.00 to repair
Apr 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Nov 21, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Refrigerator Model #795.75004401 Doesn't get cold
Hi. Make sure all your fans are working. When checking fans, open the door and push the light button in. Some models the fan stops or dampers close when the doors are opened. Put your hand in front of the vent and see if you feel air. Do the same in the refrigerator and freezer. If you feel air from both, check and see of the compressor is running. There is a fan next to the compressor and should be running when the compressor is running. You have a motherboard behind a cover on the back of your refrigerator that controls all of these functions. It could be defective. Motherboard failure is common as well as compressor and evaporator motor failure. Fan Motor failure is common for refrigerators in storage for a long period of time. The motors are weak and can't start. This goes for all new refrigerators. I sell refrigerator items on Ebay as username, themackshack. Good Luck, Mack
Jan 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
364 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
