Question about Baby Gear
One Step Ahead Stroller Parts
The rear axle and left rear wheel on our One Step Ahead tandem stroller are damaged. Are you aware of any sources of spare parts for One Step Ahead strollers? I can't find the model number, but would recognize it if I saw it...
Hi i have a stroller model number j3387 jogger has bassinet has a stationary wheel but wld like to see if i can buy a swivel so its easy 2 take to store ect pls help
Posted on May 04, 2011
How to remove a rear axle on a 98 Chevy K1500 truck
first up jack up the vehicle and remove the damaged wheel
fit the spare tire and then place an indicator ( rod on a brick ) close to the rim of the spare and turn the wheel
if the axle of hub is bent you will see the rim get closer then further away from the indicator as you turn the wheel
if it is , replace the axle and bearings
if not there will be no axle damage but the bearing could be "brinnelled "( a bearing term where the balls or rollers have been imprinted into the race from impact) in which bearing failure will become evident in 10-20,000 miles
next step is to go and get a rear end wheel alignment done as there could be suspension damage that will cause handling and tire wear problems
Jul 16, 2017 | 2002 Chevrolet S-10
How to fold mia moda 3 wheeler
Step 1
Inspect the stroller's wheels and handle to identify the type of brake mechanism it has. If the device is equipped with wheel-mounted brake levers and swivel locks, use the toe of your shoe to activate these mechanisms. If your stroller is equipped with a handle-mounted brake lever, push down on the lever to engage the brakes. Some models also come equipped with a secondary-locking mechanism located on one of the rear crossbars; use the toe of your shoe to activate this feature.
Step 2
Lift the handle or press the tab securing the backrest in place, located on the upper edge of the backrest or on the crossbars securing the rear of the backrest to the frame. Grip the edges of the footrest, then lower the component by pushing it into the desired position. Pull back the stroller's canopy.
Step 3
Grip the stroller's handle and lift the device upward; if the stroller comes equipped with a safety button, press the button as you lift. Use the toe of your shoe to push on the stroller's hinges until the frame begins to fold.
Step 4
Pull the halves of the stroller's frame together until you have completely folded the device; if the stroller comes equipped with a locking latch, engage the latch to keep the halves from sliding apart.
Audi Parts
May 23, 2012 | MIA MODA Atmosferra Travel System Stroller
The entire back wheels fell off our double eddie bauer stroller - both wheels on the right and the left. We've tried to replace wheels without success. Can we order the wheels somewhere? thanks.
When you say the wheels fell off did they break of at the spokes (making the wheels useless) or did they just come off the metal stub axles? The Eddie Bauer is not a brand available in new Zealand but I've fixed a lot of strollers and the most common problem is a failed Star-lock washer. Most strollers use a star-lock to hold the wheels on, either a shiny domed one in plan view or a plain flat one hidden behind a plastic hub cap. Check this out www.bakfin.com/starlock/starlock-movies.html
Dec 03, 2010 | Eddie Bauer All Terrain Tandem Double...
The wheels on the rear of the stroller bow in??? i got it about 2 years, and barely used until now and this happens??? elite stroller
Sounds like it somehow got overloaded. Did anyone step on them? Single strollers are typically tested to hold up to 100 pounds, which is well above the weight of a child and their gear. Regardless of what happened, contact Evenflo directy and see if they will replace the rear axle and wheels. You can't by replacment wheels at any store.
Sep 29, 2010 | Evenflo Aura Elite Travel System
Good Afternoon, My question is this. I'm intersted in buying a Eddie Bauer Tandem Double Stroller price at Sears is 279.99 colour Dark blue. I have a one year old and I'm due to have my third child in...
My experience with tandem strollers is that they are difficult to manoeuvre in cities (over kerbs, grass, gravel, etc.) and hard to turn. I also found that the infant car seat into the stroller trick is short lived, and you'll need the stroller for a long time after you need that.
My recommendation would be to buy a good side by side double with larger jogging type wheels instead. Tike Tech makes a great one that folds easily and is a lot easier to push.
Nov 25, 2009 | Eddie Bauer All Terrain Tandem Double...
Broken rear wheel on graco duo stroller
You can order replacement parts from the Graco website.
http://www.gracobaby.com/
Go to the Help Center, then Order Replacement parts. You'll need the model number and serial number or manufacture date. Site helps you locate the information on your product.
Jun 09, 2009 | Graco DuoGlider 7444 Twin Seat Stroller
Evenflo Tandem stroller back wheels replacement
You may be able to remove the axle of the new front wheels and remove the wheel from the assemble, and then do the same with the rear wheels. Next replace the axle with a bolt and nut.
Dec 19, 2017 | Baby Gear
Replacement parts for 01-648 tandem double stroller
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Nov 11, 2008 | Cosco Turnabout Tandem 01-648 Twin Seat...
In need of a spare wheel
you can order spare parts directly from their UK headquarters in Wrexham. The number is 08708406727 - good luck!
Aug 20, 2008 | Hauck Infinity Stroller
Baby Gear Logo
872 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
