No spin cycle
The washing machine is filled with water, but it's not spinning. Is it fixable? The washer is more than 20 years old.
I have a SPeed Queen washings machine. The one which the draining pump and te drum work with the same belt. My belt broke .I replace it and the belt is slipping with a hel of noise.I replace with another belt with did not glip. The result is that the overload switch trip.The problem is that the machine begin to spin at the same time as it pump out the water.The only time that the machine work is when the belt slip.The there same clutch to insure the load is take up slowly or must the belt slip.
Posted on May 22, 2011
  • 639 Answers
Dear friend,
ngfam at you service!
The Neptune was discontinued for 98 design defects!!!!!!!!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
I am washing clothes in a borrowed Kenmore washer. It's probably 10 years old. It stops short of completing the Rinse cycle and never makes it to the Spin cycle. The bowl will start filling up w/ water,...
This is a typical problem with the "lid switch" on the washer. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 26, 2011 | Kenmore Washing Machines
Rough, uneven Cotton Load spin cycle
Make sure the washer sits level on the floor and that the machine can't be rocked around due to uneven foot adjustment. The feet usually have rubber cups that cover the metal bottoms--one of the cups may be damaged or missing entirely. Hope this helps!
Jul 01, 2010 | Kenmore 24032\24036 Top Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Spin cycles not spinning, does drain water before spin
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
Nov 04, 2008 | Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing machine
    check pressure switch hose
    Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
    Washing Machines Logo
    54 people viewed this question
    Top Washing Machines Experts
