Question about Graco SnugRide - Clover
Dismantleing canopy I am trying to dismantle the infant canopy cover. I bought a new cover for the car seat and it comes wih a canopy cover. I removed the canopy from the car seat but can not get the canopy arms apart so I can change the fabric. Any suggestions??
  • dancingfloss Nov 12, 2008
    I have a graco snap and go. It's an old model . I want to change the canopy and I can't unsnap the bones and I don't want to break them. model#8446lfkb I'm a grandma who can't pull it apart from the middle. Help,
    Sandy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Posted on Feb 07, 2009
How do i fix handle that is stuck and can';t get it unstuck?serial number of infant seat is: 378099
You have to pull out the side things as you're pushing the button to raise it and push both of them in to lower it. Took me about 15 mins to figure out lol
Jul 07, 2014 | Nania Baby Ride Car Seat - With Canopy -...
Hi I have just bought the maxi cosi cabrio car seat and have managed to locate the sun canopy but cannot get it out. I have pressed the silver button on the back and thats about as much as my car seat...
Good Afternoon
The silver button will cause the sun canopy to pop up about half an inch, just pull it and it will come up further and can be hooked onto the handlebar.
Jul 12, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
May 15, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
How do I remove the canopy from evenflo infant carrier?
use a tiny flat-head screw driver to pull outwards on the tab (this is a blue plastic tab on mine) that holds the white plastic u-shaped (canopy part) in. I didnt think it would be this difficult but it is... the graco ones are much easier to take off to wash.
Apr 18, 2009 | Evenflo Embrace
Taking apart the canopy to wash.
you have to unhook the tabs for the canopy that is located by th button that pushes the carrying handle back
Mar 12, 2009 | Graco Infant SafeSeat (Step 1) 8A05RXY in...
How do i reattatch the sun canopy on the maxi cosi carbrio fix? mine didnt come with one so ive brought one just need to attatch it now x
hi maria10102..hope this helps..good luck!!!
The sun canopy is located in the rim of the shell.
• Place the carrying handle in the carrying position.
• Open the rim by pushing the button at the back under the rim and releasing it.
• The sun canopy is now visible in the opening
• Pull it out and place the ends of the sun canopy with the buttonholes over the hooks on the carrying
handle
• When storing the sun canopy, make sure you place it in the rim carefully and close the rim properly
http://www.instructions.maxi-cosi.com/download/cabriofix.pdf
Mar 11, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Evenflo Infant Car Seat Canopy Fastener
There Should be a 1 800 number on the Box That you can call
and they should send the peice your missing
if not try going in to a store Where they sell simlaler Products
and see if they carry the peice your missing
I hope I have been of use
Aug 26, 2008 | Evenflo Embrace
The sun shade on top
1. Infant restraint comes with four identical canopy support parts. Thread one canopy support completely through one sewn tunnel.
2. Slide straight end of a second support into the straight end of the first support.
3. On models with four canopy supports, repeat steps one and two for the other canopy tunnel.
4. Attach canopy in the areas between the infant restraint and the handle base.
To remove canopy, reverse the steps.
http://www.gracobaby.com/assets/pdfs/instructions/ISPC089BA_ISPC106AA.pdf
Hope this helps!! Thanks
Nov 16, 2007 | Graco SnugRide 8646 - Fiesta
Need help
https://plweb.evenflo.com/faq_detail.aspx?faqid=4990 Question: How do I care and clean for my PortAbout 3/PortAbout V infant car seat? Answer: To clean pad slide the elastic loops of the seat pad off of the seat shell. Remove the harness system. Cloth pad, canopy, and head support may be machine washed separately cold water, delicate cycle, tumble dry 10-15 minutes, low heat. Wipe straps, buckles, and harness adjusters with warm damp cloth and mild soap. Air dry. NOTE: DO NOT submerge harness assembly in water. To help protect the vehicle upholstery, place a towel beneath and behind the child restraint.
Feb 23, 2007 | Evenflo PortAbout 5 Infant
Graco SnugRide - Clover Logo
2,396 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
