Question about Zoom Computers & Internet
"settings not the same on the router as pc " says the message...
Hi ..I have a dell inspiron and trying to run the zoom router from the cable set top box where the broadband comes through..(virgin media/ NTL )
Im getting the message thats in the subject line.. Just a cross between the pc and internet globe.. any ideas please?
Thanks
  • Jo Whyte Aug 26, 2008
    Ok thanks..
    Novelist:
    Scholar:
  • 158 Answers
Has the router got a wlan port if so then ask virgin to send you a seperate modem as the set-top box has conflicts with routers this is all the help I can give
Posted on Aug 26, 2008
Cannot connect my Dell Inspiron 1012 to my wireless router
what model of DLink do you have and what operating system are you using?
I have a sample of a router set up in my tips and tricks I think youll find very helpful,
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
or
try download the info you need from
www.dlink.co.nz
www.dlink.com
its not going to be to hard to fix,
have you tried running a network wizard setup yet?
Hope this helps,MISTERDJ
May 27, 2010 | Dell Inspiron 5100 Wireless Mini-pci...
I have a problem with the wirless internet on my dell inspiron laptop. I have tried getting a new usb adapter and it's still not working. I was connected to a DLink router before I moved out and the same...
your settings in the router at your new place may not match the settings in the old place. try typing 192.168.0.1 or 192.168.1.1 in your address bar and logging on to your router (this will require you to be manually plugged in with a cat 5 cable) default passwords are usually admin/admin or admin/password. check your settings to see if something is preventing you from getting on.
Oct 31, 2009 | Dell Inspiron 1720 17" Widescreen...
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Can't connect to internet
hi
check the IP settings, DNS server Settings etc any required, as well also do check if the network cable is propery conected and is working on an other system
if the router is connected to a modem then then connection from the modem is generally connected to the port named INTERNET in that case try connecting that to one of the ports numbered 1 to 4 and connect the systems to other ports
cheers
pls rate if it was any help
Jul 07, 2009 | Dell Inspiron 1525 Notebook
Setting up and configuring networks
The main problem on your setup is your router. This BEFSR41 doesn't have wi-fi or wireless capability. You can only go online on your laptop if you connect it hardwired to the router just like your desktop. You must purchase a wireless router if you want your laptop to work wirelessly
May 09, 2009 | Linksys BEFSR41 Cable/DSL Router with 4...
Wireless connection set up
Are you trying to hook up the laptop wirelessly to the pc? because then the pc would need to have a wireless card as well....sounds like I need more info, but if you are trying to do what I think you are, you should just get a wireless router instead, hook the pc tower directly to it via ethernet cable, and then setup the laptop to connect to the router. The router would hook to your dsl or cable router....what service do you have?
Mar 10, 2009 | Dell Dimension 3100 PC Desktop
Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Jan 26, 2009 | Dell TrueMobile 2300 Router (000001)
File Sharing with Home Network...only one pc talking
The message for an unplugged network cable, means you have enabled wired network, but the cable isn't there. No problem if you are connected wireless.
To be able to access files on computers over your network, you need to enable filesharing for the desired directories or disks.
Right-click the directory or disk, go to sharing and set the correct settings. Maybe you have to allow for network sharing the first time.
Please post some feedback
Apr 22, 2008 | Dell Inspiron E1505 Notebook
Wireless network problem
What operating system do you have running on the Dell? Is there a hardware/software firewall setup/installed?
Nov 25, 2007 | Dell Inspiron XPS M140 Notebook
Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Dec 27, 2006 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
139 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
