Question about Whirlpool LER5636P Electric Dryer
Dryer not heating
Dryers drum is turning but no heat, looked at the heating element and only seen one red line coming off porcelin.were do i run the other wire to or is there a diagram for it,back panel does'nt have it
  • 958 Answers
Look inside the control panel. sometimes they put the schematics there.
there should be two wires going to the heating element.
tnx 4 using fixya.
drcool
Posted on Sep 06, 2008
  • francis rivero Sep 07, 2008
    hi scooter,
    i have already a diagram for your unit, what is your e-mail so that i could mail it to you..
    tnx
    drcool
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
DOESN'T HEAT
Could be bad heat element. Lift top of dyer, or look from back side with access panel removed, or look thru door if glass door while dryer is running on a heat cycle. You should be able to see red glow of heat element coming on. If not then you will need to open up dyer and remove drum. Inspect heat element for break in coil or coils touching each other or metal frame of dryer. You can also use an ohm meter and read the restence of the coil ...should be just a couple of ohms.
If it is a bad coil you should be able to replace fairly easy. If it is not coil than you will need to check themistor or cycle control switch. Hope this helps.
Nov 10, 2012 | General Electric DHDSR46EGWW Dryer
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
Aug 15, 2012 | GE Dryers
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
No heat
Most likely you have a burnt element....A good handy man could replace the element fairly easily.. Cost of a new element about $50-$75
Apr 20, 2010 | GE DVLR223 Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Heating element in Crosley Clothes dryer
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
May 30, 2007 | Crosley CDE6000 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
155 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
