Question about Husqvarna Designer I
Husqvarva 610 i have a 1998 bike 4 gears and bottom end went so i bought a new engine of a 2000 bike 6 gears the bike would not start so i changed the magneto and fly wheel of old on to new and it worked 4 a wile then she snaped a woodworth key and the fly wheel got stuck so i cut it of now im back to the old fly wheel and magneto but got no spark wat could it be was thinkin cdi unit how easy would it be change
  • jamieriley08 May 03, 2009
    were can i get a new magneto from please iv tryd every were and how much are there
    Novelist:
  • Husqvarna Expert
  • 371 Answers
This was posted to the sewing machine category. Resubmit in correct category for a solution
Posted on Feb 13, 2010
My two week old machine is today making a groaning noise as it starts sewing, which it didnt yesterday. Any ideas, please?
take a look in belts and gears where the noise comes
if broquen changed and put some wd40
Sep 15, 2015 | Sewing Machines
Bobbin will not load on a singer touch-Tronic 2000
Please check the bobbin tension or you bought a new bobbin and case otherwise check the timings.
Jan 31, 2014 | Singer Sewing Machines
Am new to sewing, have bought a new Janome 7025. the cotton is constantly coming out of the needle when i am in the middle of sewing, have tried changing the tension but doesn't seem to help. am
make sure that you have long thread tails before you start sewing
1.they can be around 4 to 6 inches long
2.make sure the thread is pulled back behind the needle before you
start sewing.
Sep 25, 2012 | Janome Sewing Machines
Model 1425n singer sewing machine's feeddog will not advance the material. The feed doesn't seem to move. I can't locate the level to raise it. I bought a medal feed to replace the rubber one...
i think your gears inside need replacing. remove the 4 flat head screws on bottom of machine. pull of the cover and look for pieces of plastic crumbs everywhere. that was the problem with mine.
Oct 03, 2011 | Sewing Machines
I have an elna overlock Pro 5DC, which I bought new years ago. The dealer went out of business, and with her the repairman who knew Elnas. When mine developed a problem, I had it serviced by an all-brand...
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
Sep 21, 2010 | Elna Sewing Machines
Tension problem, consew 225
The bobbin should have a thin metal peice that the thread goes under to create tension, the screw closes to end the thread comes out of is the one to adjust. If they were sewing with a light thread on the machine the tension on the bobbin is probably set pretty tight loosen it a little at a time, turning the screw counter clockwise. You might need to check your top tension also if it is showing a knot on the bottom. The bottom is to tight or the top is to loose.
Nov 03, 2009 | Consew 226R-1
Replacing broken gears on Singer Touch & Sew Model 648
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Mar 09, 2009 | Singer Sewing Machines
My singer athena 2000 won't pull the bottom thread up to form a stitch. I know this is an OLD machine and I couldn't find the right selection from the list My Singer Athena 2000 sewing machine was...
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Aug 28, 2008 | Sewing Machines
Came without an instruction manual
You should be able to buy an instruction manual from Janome or even on ebay.
Jan 21, 2008 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
64 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
