Question about Maytag Neptune MAH5500B Front Load Washer
Interrupted washer won't start
I was doing a wash and hit "pause" and then "stop" to place a few forgotten items in the frontload washer.  It now won't work at all;  lights come on, but when I hit "start", nothing happens.  What can I do?
  • 639 Answers
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT FOR 3 MINUTES AND THEN REBOOT IT!
IF THIS DOES NOT SOLVE IT THEN,
this sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Fridgidaire frontloader washer stuck on pause
Hello Angela Gilmer - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. If fault reoccurs, then it typically means that the unit has a faulty door latch. If you aren't certain that the door is properly shut, then the latch assembly may need replacing. Contact a professional to assist with the repairs.
Jan 20, 2013 | Frigidaire GLTF2940ES Front Load Washer
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
