Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis quiet pack
Is not quiet, loud and seems like the drumm is turning fasterr than it should.
  • 639 Answers
Peace Friend,
ngfam1 At your service!
1-it may be the belt squealing or high pitched nosies telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on!I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Posted on Sep 02, 2008
Maytag atlantis washer(spinning problem)
Your problem sounds like a broken belt . Check and replace. Good Luck Friend.
Jan 25, 2018 | Maytag Atlantis MAV6000 Top Load Washer
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Maytag Atlantis MAV8551aww, loud grinding noise during spin cycle.
Yes. Junk It. Problems that cannot be fixed and customer service stinks
Oct 24, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Feb 28, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Loud squeal
Just found a suggested solution to this problem and it is the same suggestion I received from a colleague who worked on repairs to the these types of appliances. Have not tried it yet, but will and then post a follow up. Check out the solution at www.applianceaid.com. It is apparently the brake that stops the tub at the end of the cyclehat causes this squealing.
Good luck
Jan 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MDE7400AY Electric Dryer Logo
103 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
