Question about Kenneth Cole KC3289 Wrist Watch
Watch stops randomly and have to pull the knob and reset then it starts running again,, have replaced the battery twice,, still acts the same,,, any ideas?
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
Posted on Mar 15, 2008
  • 162 Answers
SOURCE: watch battery cover
You will need a special tool to pop it back on. Any other way will result in the crystal breaking.
Posted on Aug 04, 2008
SOURCE: Stop Watch not resetting
DO NOT REMOVE THE HANDS ON YOUR WATCH!! pull crown out to second position then press button on dial you want to zero out. each time you press it, it will move 1 increment
Posted on Sep 14, 2008
  • 2334 Answers
SOURCE: watch stopped running
Examine the caseback of the watch. You will find the lip (small gap between the case and caseback). This is exact point where to insert watch openers blade and pry caseback up.
Rate me, please.
Posted on Mar 26, 2009
  • 2334 Answers
SOURCE: Can't pull out knob on side of watch to change time
You may have screwdown crown. Try to unscrew it first and then pull out. If the crown is turning but you can not pull it out, there is a rust in the watch and you will have to find your nearest watchmaker to sort that.
Rate, please.
Posted on Mar 28, 2009
How can I start it to run
if brand new , there will be a small piece of plastic holding the winder knob out
pull it out and push the knob all the way in
that plastic stops battery connection so that the battery is not flat when sold
any other problems , take it to a jeweller
May 06, 2016 | Timex Womens T2M828 Classic Two-Tone...
How to set the day of the week
here is your manual (I think)
If not, their site is pretty good.
nice video but as good as a chocolate teapot!
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more :
Sep 13, 2015 | Invicta Watches
Why does my Gucci watch quit running every few days?
You can start by fitting a new battery & monitor it &see what happens good luck
Aug 20, 2014 | Watches
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    I have 4 seiko watches that no longer work. Most unreliable watch
    mcdevito75 here, hello Diane, I'm afraid your jeweler is correct, and so are you. It is adviseable to pull the stem out to save the battery BUT, only if your not going to wear your watch for a long time, not just over night, here"s the problem!! the quartz mechanism and most of the works are plastic, and plastic while fairly flexable when new, gets hard over time, your pulling the stem to stop the watch everyday or even once a week most likely broke the switch in the mechanism that starts the watch, if so your only option is to replace the movement if you can get one. Pull the stem to stop your watch only if your not going to wear your watch for say 2 weeks toa month.
    Feb 06, 2010 | Seiko Ladies Two Tone SUJ614 Wrist Watch
    I need to reset the hands
    Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
    On my watch I can adjust it by doing the following...
    To reset the microseconds hand / top right
    1) Pull the center knob full out (2 clicks)
    2) Press the bottom push button to adjust the hand
    To reset the seconds hand / middle
    1) Pull the center knob a full out (2 clicks)
    2) Press the top push button to adjust the hand
    To reset the minutes hand / top left
    1) Pull the center knob out half way (1 click)
    2) Next press the bottom push button to adjust the hand.
    Once all hands are reset, push the center knob back in fully...done
    Mar 16, 2009 | Swatch Irony watch
    What are the dials? How do you set knobs? Can't move center knob.
    The 3 dials are the chronograph for timing an event such as motor racing(a stop watch). The centre know (the crown) has to be unscrewned counter clockwise and then pulled out from the case at, first stage will allow changes to date, second to set the time.
    The outside bezel is used as a means of measuring time, eg. 20min, from a random starting point and is often used for 'oxygen' time for diving.
    Feb 12, 2009 | Rolex Daytona 116528 Wrist Watch
    Buttons stopped working
    Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
    Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
    NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
    Good luck.
    Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
    Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
    Kenneth Cole KC3081
    if you pull the crown out to the #2 position,then push the start/stop pusheryou will move the sweep sec. hand up to the 12 o'clock position. push in crown. Don
    May 22, 2007 | Kenneth Cole KC3271 Wrist Watch
    Kenneth Cole KC3289 Wrist Watch Logo
    75 people viewed this question
    Top Kenneth Cole Watches Experts
    Jimmy Accardi
    Ansel Alberto
    Ansel Alberto
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
