Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Computer cannot detect canon powershot sd750 - Canon PowerShot SD750 / IXUS 75 Digital Camera
  • Sri Raghu
    Sri Raghu May 11, 2010
    HI,
    If its windows 98SE,XP,ME,2000,VISTA then try plugging the camera to different USB sockets\ports.(My suggestion would be try connecting the camera to one of the ports at the back of the computer.And as soon as u connect you should get a message FOUND NEW HARDWARE.)If you dont get this message not to worry.Go to MY COMPUTER.Look for removable drives of the camera and that simply means that the camera is being recognized and u can go ahead and transfer the pictures from the camera to the computer.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Aug 18, 2012
t00nz
  • 4738 Answers
SOURCE: Canon Powershot SD750
If purchased less than 30 days ago, take it back to the store for a replacement. If the store can't help you, Canon should then help you under your warranty. If Canon won't help, try these as a last resort:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 30, 2007
  • 11967 Answers
SOURCE: canon sd750 powershot lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 26, 2010
SOURCE: how do i turn on the date stamp on my Canon Powershot SD750
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Posted on Feb 12, 2010
  • 906 Answers
SOURCE: I have a Canon PowerShot SD750. I dropped it and
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
Posted on Jul 27, 2010
lock123
  • 6831 Answers
SOURCE: when i turn on my canon powershot sd750 the screen
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
Canon PowerShot SD750 says no memory card when there is one in...
Try to clean the fingers gently on the card with alcohol and a q-tip. Aside from that, it could be dirty contact fingers in the camera, or other circuitry. Also, the memory card could be bad, try another one to see if it's detected. Not sure if I recommend servicing anymore, since cameras have come down in price and are pretty much "throwaways" these days. Often, the repair will cost more than you would spend to get a new one.
Mar 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My daughter vomited on my Canon PowerShot SD750 (Black)???
Get an estimate of the repair cost and then decide whether to get a new one or not.
Aug 12, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error restart camera SD750
somebody saying under warranty
http://www.digitalcamera-hq.com/digital-cameras/canon-powershot-a570is_question.html?qid=12688
May 30, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera is not detected by computers I have a Canon SD750. Camera is not detected by the Windows XP SP3. A USB generic driver is added, and that's all. No removable media becames available. Canon software...
You may have a defective USB cable. Try a different cable, or try plugging the cable into a different USB plug on your computer. If neither of these work, the camera may have a defective USB plug on the camera. Double check that the camera is turned on. If all else fails, you can copy the photo files by removing the memory card from the camera and putting it in a card reader built into your computer, your printer, or use a separate memory card reader. You can buy them at most camera and computer stores - they are inexpensive, usually less than $20.
Dec 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Computer cannot detect camera
download this and clean the registry
http://www.filehippo.com/download_ccleaner/
kind regards and please don't forget to rate us
Dec 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Need software
Here ya go straight from the Canon website. Select the "Drivers and Downloads" tab to find and download the software that you're looking for:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=14919#DownloadDetailAct
Mar 08, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon powershot sd750
The AC adapter for the battery charger shoud work from 110V-240V with auto detection for voltage. Look at the marking on the AC adapter and the input voltage should show 110V-240V. Once you verify this, the charger will work on 220V and you will only need the outlet adapter.
Jan 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Digital cameras
Page 46 of Advanced User's Guide:
Press Menu, select AiAF, set it to "Face Detect".
Dec 27, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
