Question about SanDisk Sansa e250 MP3 Player
My SanDisk Sansa is going through several problems
My SanDisk Sansa MP3 player used to work fine, but one night I had it on, and the screen just glitched, and when it came back on all my songs were deleted. The next day I turned it on to see if they would be there, but little did I know it would be the last time I'd ever turn it on again.
I can't even get my Sansa to turn on, and the few times I've got it working, it shuts off within a few seconds of being in. Please help, I already bought another one of these when my last one broke, and don't need to buy another.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Sep 08, 2008
No sound from radio on sansa clip. mp3 playing still works fine.
Did you accidently pause radio. put sansa in radio mode and push the play/pause button.
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
I need to try to recieve info on getting rid of a virus off my mp3 player i think i have a vrius on my mp3.. i have a much of folder i kant erase them and songs too
if you are saying you can't delete or add media to you'r sandisk sansa mp3, it is not a virus it is a firmware error. i have had the problem myself. Follow instructons below if this is the problem.
1.Connect Sandisk Sansa To Computer
2.Go to My Computer
3.Find Your Device
4.Right Click On Your Device
5.Click Format
6.Complete Format
7.Go Download Sandisk Sansa Firmware, Follow Instructions From www.Sandisk.com
8.Everything hould Work Fine.
Dec 17, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Double check one more time - because i did not post one, but several solutions - did i reset the device? did I upgrade to the latest firmware? did I download the Sansa Recovery Tool and use it (you may have to remove the battery to update the firmware successfully or use the recovery tool)? did I try a different USB port on the same computer? did I try plugging my player into another computer?
If you tried all of the above, and it still doesn't work, then there is a hardware problem with the player and it will need to be replaced - call Sandisk and find out if you are still in warranty.
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
use windows media player in sync mode at top of screen
Jun 04, 2008 | SanDisk Sansa e250 MP3 Player
My sansa
pull the menu button 30 sec it should turn it off .. then turn it on again .. look so you dont got the lock button aktivated..
Jan 14, 2008 | SanDisk Sansa e250 MP3 Player
No Drive on Connection
Hi, When i connect my sansa e200 mp3 player with my computer..it showing CONNECTED on the mp3 player screen, but does not show any disk drive in my computer. No problem with computer, my pen drive is working fine with it. can someone help?
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
Problem with my MP3 player...
I am having the same issue. I loaded my M240 with music, then umpluged it from the USB cable. It didn't do the "building library" thing like it always does, and now when i turn it on it just loops from the "Sandisk" startup screen to the "Sansa initiallizing" screen. The same as you, when i connect it to the pc it isn't even recongnized and the player loops the "initiallizing" screen again. I put a request in to Sandisk last night, so i might have a solution for us later today.
Jun 15, 2007 | SanDisk Sansa m240 MP3 Player
My Sansa E260's screen is white and it won't turn off
After leaving it on all night and running the battery down I plugged it back in, it charged and everything is working fine. The morale of this story is, don't unplug it from the computer while it is in use.
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
Fried?
that happened to me...what i did was a just left my Sansa on until the battery ran out and then charged it.
Dec 29, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
