If you have a volt meter measure the power coming out of the power
supply and make sure the outlet is good that you are plugging it into.
Try resoldering the connection on the circuit board where the power supply plugs into it. There may be a loose connection or a crack in the board that you could jumper around using a short piece of wire soldered around the break.
