Question about Samsung LN-S4692D 46 in. LCD HDTV
Adjusting voltage on plasma
I have a HPS4253X/XAA Samsung Plasma TV. The tech came out and adjusted the voltage once before and the problem came back 8 months later. Were do I adjust this voltage and what do I adjust it to. I'm a Electronic Technican by trade so. I'm pretty familar w/ electronic circuit boards.
My warranty is out by 6 months
Also what causes these probelm in the first place. I don't see how this voltage can be changing.
2 Suggested Answers
  • 22 Answers
SOURCE: I have a samsung plasma
Did it come this way? If so I would recommend returning the TV. I'm guessing you have tried using different channels, inputs, etc. If not please do so to determine if it might be specific to an input or channel. This is not something that someone will be able to talk you through via message boards. I would first try calling the manufacturer and then the retailer if you continue to have problems.
Posted on May 05, 2011
I have a samsung plasma 42" model hps4253x/xaa -the plasma has a green vertical line at the left side.
May 05, 2011 | Samsung SP-R4232 42 in. Plasma HDTV
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Mar 15, 2010 | Samsung PN50A400 50 in. HDTV Plasma TV
Samsung plasma red fuzz on black screen
Most likey its a bad panel, you can try adjusting VS voltage on Y main board, if this is to complex you will need a tech
Aug 09, 2009 | Philips 42PF9630A 42 in. Plasma Television
Model hps4253x/xaa vertical lines throughout screen
Need more specfic info. Are the lines on all sources? Are the lines as thin as a Pinstripe?. The possible causes are: The Main bd is bad or the P-Logic bd is bad or the Plasma Panel is bad. Have a trained samsung tech troubleshoot the set.
Jul 13, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Blue pilexlation on 42 inch samsung plasma
there is no upgrade to fix this problem, you need to adjust the VS-voltages and the V-scan voltages
Jul 17, 2008 | Samsung HP-T4254 42 in. Plasma Television
Blue tint
This is usually caused by an over voltage on one of the panel voltages, if you open up the set and look at the panel you will find a sticker with the panel voltages on it, if you adjust the VS voltage down about 10 volts it will go away, if it doesn't the adjust the Vscan voltage down about 5-10 volt
Apr 11, 2007 | Samsung HP-P4271 42 in. HD-Ready Plasma...
Samsung plasma PS42D5S
You need to adjust the panel voltages, adjust the VS voltage to around 186 volts, if that doesn't change it then adjust the V-Scan voltage down, turn the unit on and apply a video source to it, and while adjusting the voltages look at the screen and you should be abe to watch the video noise fade out.
Dec 14, 2006 | Samsung PS42P2S 42 in. Plasma Television
Samsung LN-S4692D 46 in. LCD HDTV Logo
286 people viewed this question
Henry  Thomas
Henry Thomas
