Question about Uniden Cordless Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
All of a sudden, one of my handsets from the GE DECT 6.0 model 28111EE2 stopped working. First, it constantly shows a message on the screen that says "Searching...". This happens even when next to the base. Second, when trying to register the handset, it gives an error message that says "Registration Failed".
I have also noticed that when I try to go to the menu and reset the handset to the factory settings, it gives me 2 beeps and does nothing, as opposed to the good handset which I choose to reset to factory settings, gives 1 beep and shows you a succesful message.
  • jxs0189 Nov 15, 2008
    I have the exact same problem. The handset has worked for the past month or so, and just suddenly started displaying this behavior.
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Posted on May 20, 2009
Same problem
Phone was working fine.
Then starting beeping to each other, I have 2.
Then now gets handset needs registration of both phone.
Are batteries wearing out?
Posted on Apr 17, 2009
SOURCE:
I have a Uniden Cellink D1780-3BT system with 3 working handsets. I want to add Uniden DECT 6.0 D1780-3 handsets.
you will not be able to do this as they are two totally different machines with totally different operations although the 1780- appears the same it is the celllink and dect that makes the difference
you can however add as many hand sets of the same model as you wish to the same model
it has to do with updated circuitry required by the telecommunications department to operate on the system
Dec 17, 2015 | Uniden Lands Phones
I have a GE Cordless phone model #27909 dect. 6.0 i can hear people talking to me, but they can not hear me....what is the problem?
that is probably your mouthpiece, it is located on the lower end of your handset and you have to open unit first to have it replaced. you could check that it has contact and nothing is blocking it before replacement.
Regards
Aug 19, 2010 | GE 28111EE2 Cordless Phone
Handset does not work but shows normal window words.
hi gus
i want deatils on 9829645009
plz emergancy.
Mar 17, 2010 | GE 28111EE2 Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Model 28821 Series DECT 6.0, stuck in search mode
Removed battery for a few minutes and it reset.
Oct 02, 2009 | GE 28111EE2 Cordless Phone
I CAN'T REGISTER HANDSET FOR GE MODEL 27911 DECT 6.0
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
I have a GE model 28213EE2-A Dect 6.0 with base and additional handset-no answering system. The handsets go out of registration all of the time. I have called Thomson/GE and I get a run-around. They say...
I too have the same problem with this phone. It goes out of registration and the caller ID does not work. It works on all the other phones in our house.
Jul 25, 2008 | Lands Phones
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
Uniden Cordless Phone Logo
1,055 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
