Question about Fuji MX-1700 Zoom Digital Camera
MX 1700 Download Speed
Ust got a MX 1700 yesterday, cool camera and resolution is good. But downloading the pictures to my PC is very slow using the Pshuttle. Does anyone know of a better and faster way of downloading to PC without investing a large amount.
    Master:
  • 425 Answers
How about you mail in the rebate for a free USB adapter or Floppy disk adapter from Fuji Film ? The link is http://204.178.120.64/FREEFD.PDF Hope that helps!
Posted on Sep 04, 2005
SOURCE:
Why does it freeze trying to,get programs
Typically stream freezing is caused by a slow Internet, or download speed. Unfortunately most Internet service providers don't give you their full speeds as advertised, and some actually "throttle-down" you speed during heavy usage periods, leaving the user wondering why everything got so slow. 5Meg download speeds are sufficient to handle a single High-Def stream, yet uninterrupted lower resolutions can be achieved at just over 1Meg. Then there's the compression technology used to send the stream. Netflix for instance has excellent compression, and will also automatically detect a slower connection, reducing the quality, or resolution, delivered.
You can try testing your upload, and download speeds at a number of test sites... Try Googling "Speed test" here's an example: Speedtest net by Ookla The Global Broadband Speed Test
Unfortunately these tests don't provide a complete picture of what's happening when applied to streaming results, as providers usually allow a few minutes of top speed initially then begin their slow-down.
I'm able to stream two separate movies, uninterrupted, from Netflix, at just under 3Meg, on DSL. Some cable providers claim high speeds, but curiously are unable to deliver uninterrupted streams unless you upgrade your service at an additional monthly cost?
Mar 14, 2015 | Roku 3
I cannot download pics from my Camera-Samsung PL100 to my PC. I used to download before but since yesterday, i cant. How can this problem be solved.
When you connect your camera to your PC, is it recognized by your computer?
If so, when you connect your camera to your PC there will be a pop-up prompt asking you what action you want to take. Select "download pictures".
If you don't see a prompt, go to "My Computer" and see if it is listed under the device list. Right click the icon for your camera and find an option to explore the camera or download pictures. Once you can see the files stored within your camera's memory card, drag and drop the picture/s to where you want them saved on your PC.
Mar 01, 2011 | Samsung L100 Digital Camera
Extremely slow internet downloading speed.
Download this small application.
http://www.bandwidth-meter.net/bwmeterpro_setup.exe
and check your Upload and download speed.
it should not be your modem or your system problem.But a system whihc is infected by Adware, malware or spyware are usually slow during browsing.Scan you rPC with a Good anti-Virus with lastest updates installed.
Contacting your Internet Service Provider may most hopefully solve your problem.
Jan 04, 2010 | Computers & Internet
Pics out of focus
Sounds like "Camera Shake"
With Digital photography, any motion of the camera will tend to blur the photos. You'll see double edges in some photos, and plain fussy pictures in others.
The sharpest photos come from cameras sitting on stationary objects while the picture is taken.
Depending on how advanced your camera is, there are a couple of settings you can toy with.
One is the ISO setting which mimics the "Film Speed" exposure rating of camera film measured in as ISO100, ISO 200, ISO 300, ISO 400.
The Ratings are a balance between Fast action light capture, and slow higher resolution detail light capture.
ISO100 will make a cyclist passing by look like they're standing still.
ISO400 will make a cyclist passing by look like a blur passing by.
ISO100 will have larger dots of colors on the picture, (Low Resolution)
ISO400 will have tiny dots of colors on the picture, (High Resolution)
So, ISO setting is a matter of getting the best picture without the blur; get as close to ISO 100 as you can.
The other setting is Shutter Speed.
Some cameras will allow you to slow the shutter speed down to help get clearer pictures in dark environments, like places with high ceiling lights, or outside after sunset.
Again you want the fastest option available, here the balance is the same as the ISO, bright clear picture versus dark blurry picture, so you want the shortest shutter speed possible.
This is measured in fractions of a second, and often only the denominator (lower half) is mentioned, like this:
1/8 of a second is called 8 or (125 milisecond)
1/4 of a second is called 4 or (250 miliseconds)
1/2 of a second is called 2 or (500 miliseconds)
1 whole second is called 1 or (1 for one second)
On digital cameras it often simply mentioned as the fraction in a menu called shutter speed. The default is often the fastest capable speed.
Browse the menu options for ISO and Shutter speed to see what modifications you can make.
Remember it's about capturing the light, so bright sunny days are easy highest speed settings, but shady or indoor environments will take practice and fine tuning.
Also, make use of the timer delay option and set the camera on a stationary object to capture the clearest sharpest images.
Have Fun.
Jul 28, 2009 | Casio Cameras
Slow for open file at freehand mx 11
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
May 18, 2009 | Macromedia Freehand MX 11 for PC - Upgrade...
Photo,s are too big for sending by e-mail
You can set the resolution on the camera for lower resolution. You may not want to do this if you are planning to print the photos on a printer especially if you want larger prints. The best solution is to download the pictures in the cameras resolution and then reduce the resolution using a graphics program such as photoshop to a web format resolution.
There are shareware programs that can also reduce the resolutiion once loaded onto your PC.
May 17, 2009 | Fuji FinePix S8000fd Digital Camera
Grainy pictures
You have likely set the camera to shoot photos in low resolution, or high ISO or both. Check your camera manual for detailed instructions on how to set these options.
If you don't have your computer manual, you can download one from this page at Canon.com. This is for the Powershot S500, this is the same camera as your IXUS 500, they just gave it a different name in different countries.
Always set the camera to shoot in the highest quality resolution mode. Memory cards are relatively cheap and you don't want to end up getting that photo of the lifetime but because you shot it in a low resolution mode you can't get a good print!
If you are shooting in low light the camera may be automatically boosting the ISO. There are only 3 ways to shoot in low light:
1) Flash - only works when your subject is relatively close to the camera.
2) Increase the ISO which results in noise in the dark areas of the image.
3) Use a tripod and a long shutter (slow shutter speed).
Dec 19, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Can not download pictures on computer- "Communication error" showing on camera display window; camera chip 2GB with 4100 pictures. Tried using another 2GB chip with less than 100 pictures in it...
Start deleting pictures base on how good they are, importance and priority. Then by trial and error delete 50 pictures, download; 100 ... 200. Finally it download ... after 10-15 seconds wait. Total pictures deleted 1700 out of 4200. So there is a limitation on this type of camera with a 2GB chip, you have to stop taking pictures and change camera
chip when the total count reach 2500 + or - 50 pictures.
Aug 28, 2008 | Cameras
Fuji-mx1700 and night shots
Use the manual set up ( the small camera icon with the "M" next to it. Play around with the flash settings and set your flast to night. Check out the manual on this feature. I just got my 1700 last week. The Halloween photos were a lot of fun. Its also my first digital camera and there is a lot to learn. I read every thing I could find on the web prior to my purchase. I felt the MX1700 was the best value. So far this camera has met or exceed all my expectiations.
Sep 04, 2005 | Fuji MX-1700 Zoom Digital Camera
Fuji MX-1700 Zoom Digital Camera Logo
65 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
