Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite Trio Refrigerator - ice maker shut off arm
The ice maker is in the freezer section. When the ice bin is full and I open the drawer that holds the ice bin the shut off arm drags cubes at the top of the bin and drops them down into the bottom of the freezer. Finally, a couple of days ago the bottom of the refrigerator had gotten so full of cubes that the freezer drawer would not close completely. I had to use my shop vac to clean out the tossed cubes. The only way I can avoid having cubs dragged into the bottom of the freezer is to reach in and raise the shut off arm as high as I can while simultaneously pulling out the bin drawer. That takes some doing. It is awkward. Is something not installed correctly? Does Kenmore make an ice maker for that freezer section that has an electric eye to shut off the unit when the bin is full? That would eliminate the problem with the shut off arm.
  • 1 more comment
  • thepadre Aug 26, 2008
    techexpert12 says the only solution is to set the temp controls properly. Well, they have been set precisely as the manual recommends, 0 degrees for the freezer and 37 degrees for the refigerator, ever since the refrig was purchased and installed over a year ago. By the way, we've had this problem ever since the ice bin was first filled. Thanks for any further advice you can give me! thepadre
    I think I am a careful reader. I can't find anything in this information related to my problem.
  • Anonymous Mar 29, 2014
    how do I get the drawers in the freezer so I can get to the ice maker to replace it?
  • 6,487 Answers
This link will be helpful to your problem , check this out this is the link for it http://www.fridgedoctor.com/fridge-doctor-book/ice-maker-not-working.html
Hope that helps........
Posted on Aug 26, 2008
  • 2,071 Answers
The freezer compartment is icing up See the “Cooling is poor” section above.
The food in the refrigerator freezes This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
There's water dripping inside the refrigerator Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Hpe this may help;
    Master:
  • 521 Answers
Adjust the temprature properly.thats the only solution.
  • tech expert12 Aug 26, 2008
    then may be the thermostat of the unit is faulty .if its under warranty get it checked.by a company technician for any replacements required.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
We have a 7 year old Kenmore Elite trio. The ice maker continues to make ice, but won't dispense it. It appears that the plastic ice shut off arm is stuck in the up position. How can I get it unstuck
Most arms on ice makers are metal.
You might have to take the food out of the freezer temporarily and put the food in an ice chest and disconnect the refrigerator and let it unfreeze the plastic arm.
Jun 14, 2017 | Kenmore Refrigerators
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Glide rails on kenmore bottom drawer freezer keep freezing up
I suspect that you've got a leaky ice maker. Do you have clumps of ice in the bin, too? Many times, replacing the ice maker will solve the problem.
Jul 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Just bought a kenmore elite bottom freezer trio model and display panel shows o ff. Expect this means whole unit is off but manual does not say how to turn ON in the setting the controls section of manual....
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator won't stop making ice
sometimes when you pull the shelf in and out, it will bind on the shut off arm and cause it to "pull out" of the i/m module. the arm has to be put back into the back of the module. you can take the i/m out of the freezer or just use a mirror and look for the place the arm goes. it looks like a 1/4", round, white plastic slot. the arm just pushes into the white piece and thats what causes the i/m to shut off when full or when the arm is lifted up.
Dec 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Funny fridge noise, kenmore elite trio
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker not working
In my freezer, there's an infrared beam positioned over the top of the ice bin. If the bin is full of ice, it blocks the beam and no ice can be made. In addition, when you open the freezer door, a small (2x3") door opens in the freezer to block the beam, again to prevent ice from being made while the door is open. Is anything blocking the path of this beam from one side of the freezer to the other?
Mar 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
503 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
