Question about Whirlpool Duet GHW9150P Front Load Washer
Actually it's a Duet "HT" Model No# GHW9250MW2
We have a Whirlpool "Duet" HT front loader Model# GHW9250MW2. The last load completed was taken out for drying after about 5 hours (it had been forgotten about), but as it turned out, was still wet. So we set it for "Drain and Spin" and after completion it was ready for the dryer. After a day of non-use, I went out to do another load, and discovered that the drum had water in it, to the point of nearly flowing over the door threshold. I checked for back flow from the drain, and it was clear. And then I noticed that where the water enters the washer, just inside the door, there was a very slight and nearly unnoticeable stream of water gliding down the rubber seal. My guess is that there is some sort of water control valve that has failed. Please advise. Thanks
  • Sarnt Aug 26, 2008
    jsrock516,
    Thanks for resolving the problem for me and explaining the mechanism as well. After disassembly and careful cleaning of the water inlet valve, all is back in order. Thanks again.
    Sarnt
  • 5,911 Answers
Sounds like you have a water inlet valve that is leaking by. It is a solenoid controlled valve where the fill hoses hook up to. They sometimes become gunked up with rust or sediment and the diaphragms may not seat properly when the valve is in the closed position. This is particulary true if you live in an area with hard water or use well water. You can remove the valve and try cleaning (distilled white vinegar works well), or simply replace the valve (if you do not wish to repeat the process of removing the valve twice if cleaning does not work). If you wish to replace the valve follow these steps:
1. UNPLUG the washer before servicing.
2. Turn off the water supply lines and remove the hoses from the washer.
3. Remove the washer top panel by removing the three screws that hold the panel in place in the rear. With the screws removed, the top panel will slide back then lift off.
4. The water inlet valve is mounted to the back panel of the washer on the left hand side (facing from the front). Disconnect the electrical connections and dispenser hose.
5. Remove the mounting screw(s) holding the valve assembly in place and remove.
6. Reinstall new valve assembly using the previous steps in reverse order.
A new assembly can be located at searspartsdirect.com. Just type in your model number and located item number 1 (part #8181694) under the "Dispenser Parts" heading. Another website that also carries the part is repairclinic.com (item number 906483). Both are good resources for obtaining parts, however Sears also offers helpful illustrations as well.
Good catch on the symptoms. This problem can also be caused by a drain problem, caused by a siphoning condition allowing drain water to back up into the washer. I have a write-up that explains siphoning under my "Tips and Tricks" section under my profile if you wish to read it. However, you did mention you noticed water trickling in near the door, which leads me to believe you have a water inlet problem. This is the only component between the dispenser and fill hoses that controls the water shutting off. If you need further assistance, please let me know. I hope this helps you resolve your problem.
Posted on Aug 26, 2008
2 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: Whirlpool Duet HT Model # GHW9350MW2
Dear jwarbonnet,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Unresponsive control panel- Whirlpool duet dryer 4 years old
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet HT Front loader
actually the code is probably fh which indicates no water in tub ..possible causes would be water siphoning out due to low drain or tight fit in stand pipe ..if these are ok suspect flow meter ..the small round object on left with 2 small hoses attached 1 from fill valve other to dispenser...also possible pressure swith on right side ..suspect flowmeter 1st if it has one
Nov 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dear jwarbonnet,
Neil
Aug 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
243 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
