Question about Vivitar Cameras
How do I open the back of camara vivita 4000s to reload
  • 550 Answers
Try lifting the rewind knob up, after the film is fully rewound, often the same motion to release the film canister releases the camera back
Posted on Aug 26, 2008
Ewi 4000s cutting off
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Feb 09, 2014 | Akai Ewi4000s Electronic Wind Instrument
Akai ewi 4000s neck strap mount
1 Un screw all the screw on black panel, but must remember where each on goes, but Be careful not the two screws in side mouth pice which holding the pitch bend unit. 2. open the battery cover remove all the battery 3. Remove the 1/4 earphone nut, and all screws on the silver metal case. (Under the black plastic ), you don't need to remove any screws from the "key" side 4. Use something to pull the battery Cartridge sideway out from Main attachments, but not all the way out from the ewi case, because you can't, the plastic case structure will be in the way, 5. Use some flat pice metal like dinning knife insert in to between black and sliver metal to separate the two parts, start from the mouth pice end, once you open wide enough the battery cartridge can be remove from the case out. Now you can open the Ewi 4000s and see the two HX nuts that holds the strap mount, put some Nail polish on it before you tie them up.....Warning.. You must pull the battery cartage sideway out from its electric plugging mount before you are trying to separate the plastic and silver housing otherwise you will damage the circuit board. That was What I did to mine. Good luck and may God provide you wisdom for this.
Apr 22, 2013 | Akai Ewi4000s Electronic Wind Instrument
My comp says there are no photos on my camara. They are there because I can see them on the camara. I have tried everything I can think of including reloading the program. Any suggestions?
Ok, well I have had a similar issue with my samsung cell phone and my digital camcorder. What I did was remove the memory card as the pictures were saved on the actual device rather than the memory card. It wouldnt see the other pictures as it will automatically access the memory card first and gives no options to switch. Try that and let me know of that works
Jul 26, 2009 | Nikon Coolpix S600 Digital Camera
Camara on blackberry phone does not work
Try turning off the phone and then removing the battery for a few minutes. Replace the battery and then then let the phone reboot, it should work fine after it reboots.
May 31, 2009 | AT&T Blackberry Curve 8300 Smartphone
My akai ewi 4000s kind of froze
Please try to reset the ewi. You can do this like this: Shut down ewi. Press down the four little white buttons Level, FX, Setup and Trans. Keep them pressed while starting up the ewi.
This is a factory reset.
I hope this works for you.
Apr 03, 2009 | Akai Ewi4000s Electronic Wind Instrument
Akai 4000s Wind Synth
This is a common fault - faulty capacitors in the power supply section need replacement. Low and noisy voltage rails are stopping the Akai initialising properly.
Please rate the assistance given - this should enable you to fix the problem.
Mar 23, 2008 | Audio Players & Recorders
Can I change operating systems?
I did it on my laptop because I dont like vista either. Just make sure to look up all the drivers for your hardware before you reformat the system. Most drivers are available in the XP version. Then just reload it and put on the correct drivers.
Jan 28, 2008 | Acer Aspire 5610-4648 Notebook
Cameras Logo
32 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
