Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Model # GHW9350MW2
We have a Whirlpool "Duet" HT front loader Model# GHW9250MW2. The last load completed was taken out for drying after about 5 hours (it had been forgotten about), but as it turned out, was still wet. So we set it for "Drain and Spin" and after completion it was ready for the dryer. After a day of non-use, I went out to do another load, and discovered that the drum had water in it, to the point of nearly flowing over the door threshold. I checked for back flow from the drain, and it was clear. And then I noticed that where the water enters the washer, just inside the door, there was a very slight and nearly unnoticeable stream of water gliding down the rubber seal. My guess is that there is some sort of water control valve that has failed. Please advise. Thanks
  • Sarnt Aug 26, 2008
    Ngfam...
    Forgive me... but who is this jwarbonnet that you are responding to. And does this mean that their problem matches mine?? Your trouble shooting expertise is greatly appreciated, but please confirm that you were actually speaking about my situation referenced above. Thanks.
    Sarnt
  • 639 Answers
Dear jwarbonnet,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
  • Neil
    Neil Aug 26, 2008
    Sarnt,
    I'am sorry about that,yes this is for you!
    Good luck. You will be alright!!!
    ngafm
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Unresponsive control panel- Whirlpool duet dryer 4 years old
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Actually it's a Duet "HT" Model No# GHW9250MW2
Sounds like you have a water inlet valve that is leaking by. It is a solenoid controlled valve where the fill hoses hook up to. They sometimes become gunked up with rust or sediment and the diaphragms may not seat properly when the valve is in the closed position. This is particulary true if you live in an area with hard water or use well water. You can remove the valve and try cleaning (distilled white vinegar works well), or simply replace the valve (if you do not wish to repeat the process of removing the valve twice if cleaning does not work). If you wish to replace the valve follow these steps:
1. UNPLUG the washer before servicing.
2. Turn off the water supply lines and remove the hoses from the washer.
3. Remove the washer top panel by removing the three screws that hold the panel in place in the rear. With the screws removed, the top panel will slide back then lift off.
4. The water inlet valve is mounted to the back panel of the washer on the left hand side (facing from the front). Disconnect the electrical connections and dispenser hose.
5. Remove the mounting screw(s) holding the valve assembly in place and remove.
6. Reinstall new valve assembly using the previous steps in reverse order.
A new assembly can be located at searspartsdirect.com. Just type in your model number and located item number 1 (part #8181694) under the "Dispenser Parts" heading. Another website that also carries the part is repairclinic.com (item number 906483). Both are good resources for obtaining parts, however Sears also offers helpful illustrations as well.
Good catch on the symptoms. This problem can also be caused by a drain problem, caused by a siphoning condition allowing drain water to back up into the washer. I have a write-up that explains siphoning under my "Tips and Tricks" section under my profile if you wish to read it. However, you did mention you noticed water trickling in near the door, which leads me to believe you have a water inlet problem. This is the only component between the dispenser and fill hoses that controls the water shutting off. If you need further assistance, please let me know. I hope this helps you resolve your problem.
Aug 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
