Question about Sony KP-53XBR45 53" Rear Projection Television
I have a pic problem is it fixable
Got an older big screen, works good for the kids...picture bowing on both sides
  • ryan d Aug 26, 2008
    its actually KP-53xbr35
  • tonyreed3 Jan 14, 2009
    The sides of my KP-53XBR is doing the same pin-cushioning. It just started and corrects itself after a few moments, but I believe it is occurring more often. Can you tell me what might be the fix?
    thanks,
    t
  • 4,234 Answers
If the picture is bowing in on the sides, this is called a pincushion problem. Please confirm that your model is KP-53XBR45 and I'll look up the probable defective parts.
Dan
Posted on Aug 26, 2008
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Philips magnavox 6P6030 W101 picture is too big and can't see the outer edge of the full picture
Not easy with a older set----look to see if a physical control exists in the set for Vertical size (picture too tall) and the adjustment may only exist in a hidden on screen menu.
Jun 11, 2012 | Televison & Video
My 52" RCA P52937SG screen
the part is called the convergence ic. replace those ics.
Mar 22, 2011 | RCA 32F531T 32" TV
The pic is off there is bowing at the top and
Picture becoming distorted at the top/bottom of the screen is due to the convergence circuit going bad, and is a common issue with big screen projection TVs.
The convergence circuits will need to be repaired, which will generally require some soldering and ordering new parts for ~$75. If you want to get a TV technician to repair it then you will probably be looking in the region of about $300 for a repair.
Here is a link to repair guide for a Mitsubishi TV. Obviously a different model, but the convergence circuits are generally the same for most makes/models - this will give you an idea of the work involved to fix it: http://www.techlore.com/article/22530/DIY-Repair-Replacing-Convergence-IC-s-on-a-Mitsubshi-TV-Set/
Nov 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WS-65857
easy easy problem.! simple. bad solder connections on the convergence ic's. they are located on the side of big circuit board with big silver heat sinks attached to them. they will say red,green,blue on circuit board. lift board up and solder. enjoy!!!!
Nov 11, 2009 | Televison & Video
Philips 43P8341 picture bowed red wont line up
You will need two STK392-120 convergence IC and about six 6.8 ohm 1watt convergence resistors you can get the parts at the following link and they provide free step by step instructions with pics.
http://servicemanuals.vstore.ca/
May 27, 2009 | Philips 43P8341 43" Rear Projection...
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
3 IMAGES ON SCREEN
you need to replace both convergence ICs they are STK392-120 you can get replacement ICs and free instalation instructions at the following link.
Jun 05, 2008 | Hitachi 53UDX10B 53" Rear Projection...
WT 46809 Big Screen
Good Day y'all;
When the is picture being intermittent and bowing then the most common problem is that the convergence circuit has failed or is failing. If you don't get fixed, the will go DOA soon.
Good Luck, big IRISH.
May 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
TV-Bowing
can you post a pic of your screen so i can properly diagnose the problem as it could be either a pincushion or convergence problem. A picture would clarify it for me.
Apr 16, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
135 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
