Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Horrible smell coming from freezer blower
I have a horrible smell coming from the blower in the freezer, and I have no idea what it is. Any ideas?
  • mtrapp Oct 23, 2008
    The smell is "something burning" type of smell, something electrical. It lasted for a few hours and then nothing. The freezer simply stopped working. Everything started defrosting. Fan seems to work. Is there anything I can do? (I'm reasonably handy)
    Thanks for taking the time on this with me.
  • 24 Answers
What sort of smell please be more specific.
Posted on Oct 08, 2008
Why does my new Crosley refrigerator smell like oil in the freezer section?
Get it replaced or paint it lemon yellow. If they argue ask for your money back, if that is a problem contact your BBB and the manufacturer. It comes with an implied warranty to perform.
May 17, 2017 | Refrigerators
We have an older model freezer. The door was left open and we had cleaned up the mess. Now we have a horriable smell around the exterior of the freezer. The interior does not smell. Do all freezers...
Have it clean and use a appliance cleaner that has fragrance to smell it good again.
You must eliminate the source of horrible smell.
Then apply the cleaner on rags, wipe it around the freezer exterior.
Some freezer do have pan and some don't have, so you should look for it carefully.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
There is a horrible foul smelling fish like odor coming from the freezer. It has been cleaned inside and out and we found a dead mouse under the freezer but removed it and then cleaned again. There has...
This is just an idea. the sounds may just be age.. some systems are louder than others and some that are noisy become quiet. But the smell concerns me. It may be that there is something in the cooling fins that is producing the smell. The air from the outside does not directly go into the freezer so I don't think the mouse is the issue. Problems like this usually end up coming from the insulation inside the walls of the freezer. But since you have no history of the freezer loosing power and fish going bad I can suggest anything...If you have any easy access to the inside of the freezer try and take a look. One way to possible clean the smell is to put a bunch of charcoal briquettes on some cookie sheets and put those inside the freezer for a day or two. then switch them out... also you can put a pan of armor hammer backing powder down inside and change that every other day. good luck
Sep 17, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
I have a Kenmore washing machine and so far I haven't have a problem with it...the problem is that most of the time when we do laundry a horrible sewer smell comes out. It doesn't seem to be coming from...
You are probably correct with the idea the sewer smell is not coming from the washer but rahter then drain line. Was this recently installed or has a slow drain down the pipe? There is suppose to be what is called a P-trap installed in the drain pipe to restrict the gases from coming back into your home. Check the drain line. If I can help further, I am here. Eric Campion
Mar 03, 2009 | Washing Machines
Heater core or blower motor?
Sounds like your blower motor , you heater core is a non mechanical part and if it were the issue you are correct in thinking you would see fluid on the floor or mist on the windshield.
Dec 17, 2008 | 2005 GMC Envoy
Blower motor 1995 ford explorer
if ur blower only came on the high fan speed i say it was ur blower resistor , but ur blower aint working at all so i would replace the blowerand the resistor cause they eventualy good out with when then the blower problems
Oct 27, 2008 | 1995 Ford Explorer
NOt keeping food cold
Good posibility that some thing is wrong with the defrost system. This is not as expensive to repair as a compressor. Is it worth it? The compressor and having it replaced and recharged will run much more than 250 a lot of the time or very close to it. Unplug it for a few hours with the freezer door open. Then plug it back in and see if it starts freezing again. This would tell you if it is something with the defrost cycle. The low motor noise may be the fan in the bottom of the unit. It would be good to know if the compressor is running or not.
Jan 28, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
187 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
