Question about HP Pavilion F1703 17" LCD Monitor
Flashing monitor My HP Pavilion monitor keeps flashing on and off. The cord checks out fine with other monitors, as does the video card. And the computer is fine. It acts like it needs to be reset or something, but I can find no reset button. Any ideas?
  • 37 Answers
Sounds like the power supply can't keep up with the demand. It starts to work and then shuts off and then right back on repetedly? Probably bad electrolytic capacitors in the power supply, a pretty easy fix if you can identify which ones are bad and have a soldering iron with the right type of solder and some soldering skills. Good Luck
Posted on Aug 26, 2008
My hp pavilion a 1140n turn on fine but my monitor no display pc running good
Try using a different monitor to check if it is your monitor that is indeed bad.
Also, try using a different cable if possible.
If the computer is at fault (different monitor didn't work either) then you can try installing a graphics card.
Look inside your computer and see if a slot for a graphics card is there. This will be a single unique slot unliek the others in the system.
http://www.ehow.com/video_4445579_gaming-video-cards.html?pid=1&cp=1&wa_vlsrc=continuous&wa_vrid=e626bed1-c9c1-4994-847a-0a9324874691
The video above shows how to choose and install a video card.
I recommend Newegg.com for purchasing
Feb 28, 2011 | HP Pavilion a1140n (PX774AA) PC Desktop
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
Just moved and trying to set up the computer. Monitor light keeps flashing with a blank screen
Check that the "data" cable between the monitor and your computer's video-card is tightly connected at both ends.
No "signal" reaching the monitor means nothing on the screen.
Sep 26, 2010 | HP Pavilion F1703 17" LCD Monitor
I have an hp pavilion computer it turns on fine but my monitor is not displaying anything
Before you turn the power onto the computer make sure you have the monitor on. When you power the computer up you should see a very quick flash as the computer boots up. If you don't your monitor is either bad or your video card. Make sure the monitor is plugged in tightly into the adapter that it fits into.
Aug 17, 2010 | HP Pavilion a420n PC Desktop
My fathr gave me a hp f1703 monitor. As soon as i plug it in the whole screen flashes on and off. The light on the power cord also flashes, but if i unplug the monitor and leave the speakers plugged in the...
try another monitor i re placed my cord and the graphics card and it didn't do me any good i replaced the monitor last and it works fine now. and my speakers pluged into the monitor the monitor i bought didn't have the port for speakers so now i need to get usb speakers so check it out. hope this helps
Oct 17, 2009 | HP Pavilion F1703 17" LCD Monitor
I just sent my son one of our older computers (2004) with a hp pavilion f1903 monitor - he hooked up the computer and monitor but the monitor seems to be stuck in sleep mode - what are we doing wrong ?
He may need to open the casing to make sure the video card is firmly in place. Turn the power off, unplug, press the power button to get rid of any extra juice. Make sure you're grounded and open the left side, computer front is facing you, and look inside.
Look where the monitor cord attaches, is the card firmly in it's slot? If it is, place the card in another slot of the same size, screw the card in place, close the casing, plug it in and see what happens. If it STILL won't run then I think the video card or the monitor may have been damaged.
If there is no video card then it may be the monitor was damaged.
There are other lengthier routes to try, but this is a simpler way to see what is what.
Jul 09, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp pavilion f1703 flashing orange monitor light what does this mean?
This usually means that it is not getting a video signal. Try checking the connections and make sure your video card is seated properly in the computer.
Jul 07, 2009 | HP Pavilion F1703 17" LCD Monitor
My HP Pavillion F1503 15 inch flat screen monitor has all different color lines on it when I plug it in and it wont turn on??
Have you tried the monitor on another computer? If it works on another computer but just not this one, the first thing I would check would be the video card drivers. If those are fine, you could have a bad video card.
Jun 08, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
I have my HP Pavilion hooked up to my new Acer al2216W monitor. The image comes up on the monitor but keeps flashing on and off constantly. How do I make the screen stay on?
Video Card problem. This can be caused by your onboard video card or a separate video card installed on your AGP or PCIE slot. Either way, try changing your display settings first. Set it at a lower or higher refresh rate and lower or higher bit and resolution settings.
Mar 09, 2009 | Acer AL2216WBD LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
