Question about ASUS P4VP-MX Motherboard
Unknown Hard Error
I have a problem on my motherboard asus p4vp-mx. When Im stalling my pc there an error message going out " Stop: C0000221 Unknown Hard Error \ SystemRoot\system32\ntdll.dll."
  • Pinyachta Dec 06, 2008
    Had same issue the solution worked!
    Asus P4VP-MX w/ P4 2.8Ghz, 2 GB PC2700 DDR 333 MHZ 184PIN Cas Latency (CL) 2.5 HIGH DENSITY 2.5V, Non-Parity, Non-ECC, Unbuffered SDRAM.
  • 226 Answers
It's probably a corrupted file on the hard drive due a variety of reasons. A simple defrag might fix it but it's unlikely, so it is probably preferable to a Repair function from your XP install CD. These kinds of errors with XP were not uncommon. After the Repair assuming it works and I'm fairly certain that it will, defrag your hard drive and then start getting the new updates for your system.
Illustrated procedures located here
Posted on Aug 26, 2008
  • jhaycher Apr 27, 2011
    i think its a problem with bios of mobo, coz i also encountered that problem, i change the memory, harddrive, power supply, processor, still that error appears when installing windows xp.
  • Ravel Lively
    Ravel Lively Apr 28, 2011
    Another strong possibility is the CD or DVD being installed from is causing the issue by installing a corrupted file, i.e. either the file on media is faulty and/or decompression from media is faulty, possibly but not necessarily due to a hardware issue in which case the CD/DVD reader,memory, or hard drive might be the culprit. In most cases , a clean format and re-installation from known good media will solve this issue. If one knows for sure the media is good, especially on another computer then consider the possibility that the CD/DVD reader in the suspect computer might not be reading the media properly. I have personally seen this on several occasions
There is a processor installed that the BIOS cannot recognize. Update the BIOS in the motherboard.
Also make sure the CPU is in the CPU support list, on the same page. If it is not a supprted CPU, you will get that error.
Apr 21, 2011 | ASUS K8V-MX Motherboard
Why is my ethernet is not working
ASUS P4VP-MX Driver Download - [ Vertaal deze pagina ] 27 Jul 2006 ... ASUS P4VP-MX driver download. To download P4VP-MX driver read the instructions below. ... Download ASUS Motherboard Driver. P4VP-MX preview ... - In cache - Vergelijkbaar
Oct 14, 2010 | ASUS P4XP-X Motherboard
No sound and graphics card
6 Channel Audio
The P4VP-MX uses an onboard Audio CODEC that lets you enjoy high-quality 6-channel audio without having to buy advanced sound cards.
Powerful Integrated Graphics
The P4VP-MX integrates VIA ProSavage8 Graphics to deliver powerful integrated 2D and 3D graphics performance for functionality and value.
Oct 14, 2010 | ASUS P4VP-MX Motherboard
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
Feb 03, 2010 | Intel Computers & Internet
C0000221 Unknown Hard Error\System32\ntdll.dll
From MS's KB:
Feb 06, 2009 | Microsoft Office Professional 2007 Full...
hmm...try check your Video Card...maybe the problem is in video card try using eraser use it!!
or something wrong in the board try buying a new one ^_^
Sep 03, 2008 | ASUS P4VP-MX Motherboard
Bios update for P4VP-MX
Try here.
Read the notes on flashing BIOS's before trying to flash your bios (if you stuff up I don't think there is anyway back).
Good luck.
Apr 15, 2008 | ASUS P4VP-MX Motherboard
Yahoo messenger and yahoo email
Please be a bit more specific. What is happening? Error messages? Try clearing cache and cookies.
Jan 10, 2008 | ASUS P4VP-MX Motherboard
System error loading
try restarting and go to bios,set to default config.
This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP.
See this article:
Dec 15, 2007 | ASUS P4VP-MX Motherboard
ASUS P4VP-MX Motherboard Logo
496 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
