Question about Refrigerators
Maytag MTF2455DRW refrigerator puddle on bottom of fridge needs to be wiped up 2-3 times a day..dripping down rear of fridge section to bottom
  • Tammyrf May 12, 2009
    I have the same problem. Water leaks from under crisper drawers, happens every couple of weeks. Also the ice cubes are hollow too, not sure if it's related but maybe drain tube frozen? Where is the drain tube?
aborcass
  • 2651 Answers
SOURCE: Bottom of freezer has water dripping into it
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 04, 2008
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
  • 9 Answers
SOURCE: Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Posted on Jun 14, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 2666 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
Model GX5FHTXVB03 - Bottom Freezer - ice buildup in the bottom that leaks on to the floor - Ice maker is NOT connected (no water supply to the refrigerator)
Our Amana/Whirpool fridge is 5 years old and this just happened for the 2nd time. As previous posters explained, the defrost drain tube is likely frozen. Remove all food from the fridge and freezer and unplug it for a day. This will thaw it out. Take the opportunity to clean it inside and out (wipe the interior, vacuum the condenser coils underneath). It may leak on the floor if the drip pan overflows after it thaws, so keep a towel or rag handy. I got this advice from a nice lady at the Whirlpool service number, so this is a common problem. She saved me a service call :-)
After a day, plug it back in and reload it. It should work OK. Not necessary to check circuit boards, pump air into the tube, etc unless it still doesn't work It helps to have a 2nd refrigerator handy, in my case a Maytag/JennAir that doesn't have this problem. Note that newer Maytags are Whirlpools also. I will not buy another one of these.
Oct 27, 2013 | Whirlpool GB2SHKXL Bottom Freezer...
MTG1950GR Maytag water puddling in bottom of fridge
This CAN happen (and usually DOES) when your fridge is in dire need of a COMPLETE thawing. You'll need 24 hours to store your perishables. Open doors and UNPLUG and let it thaw. You CAN hurry the process with a hair dryer, but be sure #1: you use standard precaution against electrical shock if dripping water enters your hair dryer, and #2: DO NOT overdo use of the hair dryer and melt platic parts that'll make you sorry. :)
Oct 20, 2013 | Maytag Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
My Fridgidaire Professional series refrigerator has a puddle of water in front of it about once every other day. The puddle is around the front on the freezer side of the fridge. What can I do to fix this?
Drain line in the freezer section is clogged, needs cleaning. There is a small drain pan on the bottom of the rear wall in the freezer. It is covered with ice. Defrost or remove ice, and get to the drain hole. try flushing with hot water, if does not help - clean mechanically on both sides of the drain line - in the freezer and in the back of the fridge, where it comes to the drain pan near condenser/compressor.
Oct 16, 2009 | Frigidaire Professional 26 cu.ft....
Stinky drip tray
soap and water to the defrost pan is the only way if odor is inside place crumpled newpapers in the section for 1 day then unused coffee 2 cups this will absorb odor inside of the unit
Aug 19, 2009 | Maytag PTB2454G Top Freezer Refrigerator
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water in bottom of Roper Refrigerator/Freezer Unit
I have the same problem. I suspect the drain line for the auto defrost is clogged and so the water is dripping down into the fridge. (The water from the auto defrost cycle is supposed to drain into a pan under the fridge where it evaporates over a period of a few days). I have yet to locate the drain line though.
Dec 27, 2007 | Refrigerators
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Apr 14, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
