Question about Honeywell Heating & Cooling
I HAVE PROBLEMS WITH MY T87 HONEYWELL THERMOSTAT THE SETTING ON THE THERMOSTAT AND THE TEMPERATURE DO NOT MATCH WHEN THE AIR IS ON THE SETTING COULD BE AT 75 AND THE AIR RUNS UNTIL IT IS 68
    Problem Solver:
  • 5 Answers
T87 usually are about 5 degrees off. sometimes more because of dirt and dust.get a digital
Posted on Aug 28, 2008
I have a T87 that i was replacing, red with red, white with white none of the setting fron behind work, the thermostat started to smoke, i could not connect it, what to do?
It sounds to me like you may have a defective thermostat. I would check wiring to furnace cotrol board on furnace and see if its is wired differently.If at this time of year for heat only red and white should do it. Hope this helps. Thanks
Nov 12, 2010 | Honeywell Heating & Cooling
My new honeywell T87N/T87K round is not turning on my heater
check for voltage then check connections sometimes the wire breaks and no power gets to the stat
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Thermostat problems!
You can turn off the 'Optimum Start'. See MoneySavingExpert website for instructions posted there by Honeywell as to how to do it.
Jan 01, 2009 | Honeywell Heating & Cooling
Thermostat T87
how old is unit? Sounds like it may be short cycling which could be do to it going off on limit.
Sep 15, 2017 | Honeywell CT87B ROUND HEATING&COOLING...
What position does the small lever on the right side of the T87 Honeywell Round T-stat need to be in to be OFF ?
The switch on the right side of the T87 is for the fan. Down is the auto position which will cause the fan to run only when needed. Up is the always-on position, used to circulate the air constantly. If you want to shut down all heating cooling associated with this thermostat you need to look at the switch on the left side of the stat. To the right is heating, center is OFF, and left is ac.
Dec 14, 2008 | Heating & Cooling
I've replaced my very old (mercury) Honeywell thermostat with a new one (round, Model: YCT87K1011), but I can't get it to control the temperature. If I connect the two wires one way, the furnace comes on...
Hey John, man that ole T87 has been around for a hundred years and I have installed many of them, but I cant remember the letters on the wiring. Seems to me that it is R-W-Y, any way you will use the R and W. I have a t87 at home still in the box and I could wait till I got home to help you but Im sure its the R and W terminal. Dont forget to set the heat anticipator. Set it the same as the current value of your gas or oil valve.
Nov 06, 2008 | Honeywell Heating & Cooling
Thermostat problem ?
If you start by looking on your gas valve, you should find the correct amperage to set the heat anticipator at. I am not sure if you have a forced hot water system or a steam system, but depending on the case, you may also have a second problem, which is easily addressed. If you have forced hot water, the upstairs baseboard/radiators may be airbound and need to be bleed. If you have steam, you may need to slow down the downstairs valves, and open the upstairs valves to get a balance. Hope this helps
Oct 20, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
174 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
