Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Video Input Label Displayed Constantly
Hey. I can't figure out how to turn OFF the green input labels that appear on the top left of the screen. I can change them from VIDEO 1 to LD, etc., but can't get them to go away. Can I do this without the original remote? It's gone.
  • Anonymous Mar 30, 2009
    I am having the same problem I just cant find my remote we moved is there another solution
  • 10,594 Answers
You need Sony TV remote and press Display button and screen display (green label) will disappear.
Regards,
Posted on Aug 26, 2008
Grey and green bars across the TV
You are describing symptoms of power supply failure.
Jan 10, 2014 | Shar AQUOS LC-60C7450U 60" 3D 1080p...
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
I have a Sony kp-51ws500 that shuts off and blinks 8 times, I'v read that some other people have had the same thing and it was the flyback transformer. Now my tv has just a green screen with no pi
No, the set is prone among other things to issues with the three picture tubes, go to unused video input----screen should be black with only the input label displayed-----in your case with Green screen and or slight diagonal trace lines (if there) the Green screen control itself needs to be adjusted slightly down.
I can tell you if you want how to do that---requires only a screwdriver and 10 minutes.
Dec 03, 2012 | Televison & Video
No video or sound
External Speakers
Installation steps:
Turn the power on.
Dec 27, 2011 | Nintendo Super NES Console
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
When watching a dvd, screen goes black and the word video appears on the screen in the upper right hand corner. Picture sometimes comes back, and then goes out again.
It sounds like your TV/monitor is losing the video feed. That's why it displays 'Video' - the label assigned to the input - so you'll know the TV is turned on but missing the input. You would get the same response from the TV if you turned the DVD off. I'd look at the integrity of the video connection from the DVD.
Jan 19, 2010 | Audio Players & Recorders
Fujitsu plasma tv is on but no picture on screen. monitor screen seems to work as it displays the "video input", but there's no picture
Check all inputs. Are they all dead. Try other signal source. Does antenna input work when connected to known good source?Vide input label being displayed indicates most of the tv is working. You need to determine if you have lost signal in the video input.
Nov 09, 2009 | Fujitsu P55XHA40US 55 in. Plasma...
Microphone Recording
It all has to do with your VST Connections in Cubase LE (if you are using Cubase LE).
What you have to do is:
1)Go in and label you inputs and outputs in the Device Setup. Select " US 122L-US 144" Here your inputs and outputs should be displayed. You should be able to see which input is "active" and which ones are "inactive".
2) After noting which ones are active label these devices. Click the "Show As" section and label you "active" outputs as speakers or whatever you like. Also label you inputs which should be your mic or MIDIs.
3) After labeling, click " VST System Link" and make sure the correct input and output is selected, Example: (Input: AKG Perception 220, Out-put: Speakers/ Headphones) Hit Ok!
4) Bring up the "VST Connections" menu (F4) or (Device> VST Connections). Clear out all your outputs and inputs!
5) In your outputs click "Add Bus" Select stereo and 1. This should come up as whatever you labeled the outputs ( Speakers/Headphones for me!)
6) In your inputs click " Add Bus" Select Mono and 2. Here is where you should get one input that says the name of your input( AKG Perception 220 in L) The one below it should be ( US-144 Analog R or L) Click this and choose your Microphone! You should have the 2 options with your microphone named.
7) Test it (record something) and see if it works and plays in both ears if you want more clarification feel free to message me!!!!!!!
I HOPE THIS WORKS!!!!!!!!!!!!!!!!!
Jan 01, 2009 | Tascam US-144 Sound Card
Video Label
There's a "Display" button on your remote.  Push it.
Mar 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
515 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
