Question about Honeywell Programmable Thermostat Heater
Honeywell RTH 230B Thermostat Wiring
Help!!!!!! I bought the above programmable thermostat to replace an old HW mercury thermostat. I thought it would be an easy switch..wrong!
I have an oil-fired furnace - heat only - no A/C units. On tactual furnace, there is a White wire and Blue wire connected to each of two "Thermostat" terminals (both unmarked)
The old mercury thermostat I removed was connected by two wires (blue to one unmarked terminal and white to the other unmarked terminal). There was a red wire loose and unconnected/unstripped.
I installed the HW prog. thermostat.
On the new one the connections are Rh Rc (jumpered) W Y G.
Following the instructions for 2 wire installation (I assumed since the old once was hooked with two wires, the new one was also a 2-wire installation), I removed the jumper from Rh/Rc. (correct??)
Since there were no wiring instructions with the Thermostat (duh??!) I guessed and connected them as follows:
Blue to RH
White to W
Left the red hanging as per the original.
The ambient room temp was 76 degrees. When I change the set point to 82 and switch to "heat" to test the furnace, nothing happens.
I've tried the wires in a few diferent spots but nothing!!
do I have to now use the red wire in the new thermostat??
should I have removed the jumper?? (I have a second unit with jumper intact if need to use it).
Can anyone tell me how to connect it using the colored wires I have before I jump off a cliff!!
Thank you so much in advance,
Jrhough1
  • keywest508 Nov 14, 2008
    Somewhat the same. I hooked the red to the area for the red and white to the terminal for white and removed the jumper. Increased temp above room temp, boiler started for about 60 secs and turned off. Any thoughts ?
  • 24 Answers
Put the jumper back in RC and RH and that should do it.
Posted on Apr 15, 2009
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
I installed the RTH 230B thermostat, Theheat only works when set to the cool mode, I only have gas furnace(no ac unit). My old wires are Red, white, green and blue. What wires go where?
Hey jim Try....RH/RC jumper (connected with a small piece of wire)...RH/RC=RED...W=WHITE...G=GREEN blue=unused... should give heat only (in heat mode) no ac..tks
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
CHANGED BATTERIES AND NO DISPLAY HONEYWELL RTH 230b
Electronic thermostats are powered by battery or off of the 24 volt power from the furnace or air handle, or by both. Check and make sure that you have 24 volts from the furnace. If you do have power, then you have a bad thermostat, it make have just gone bad, or got shorted out.
Drop me a line, with more info and I will be happy to help.
Have a great Evening!
Sincerely,
Paul Gibson
Apr 08, 2010 | Honeywell Programmable Thermostat Heater
Non programmable Honeywell to programmable
the 230 doesnt sound compatable with your system. you are gonna need a t stat that is compatable with Heat Pumps.
Mar 18, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,299 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
