Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Troubleshoting on installation of mb foxconn 45cmx
I'm installing a mb 45cmx, but a ihave an atx of 20 pins, but in the manual says that i can use both 20 or 24 pins atx power supply, however, the system doesn't start. I've checked the power and it's ok, the mb is receiving power. I need some help please
    President:
  • 2,351 Answers
Hi aligmatos, the total ammount of power needed for the 45CM-X board depends on what your running. If you load the board up with memory, use a PCI-E graphics card, dual core CPU, 1 or 2 SATA II's, CPU fan, case fans, floppy disk drive & 1 or 2 CD/DVD drives your system may not boot. Suggest you see my answer for your other post on this issue.
This power supply should be able to run your board:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3287208&csid=ITD&body=WARRANTY#tabs
This comes with a 5 year warranty.
Mike
Posted on Aug 26, 2008
    Novelist:
    Scholar:
  • 158 Answers
Have you placed the 4 pin block to the motherboad and also check the bois clr jumper to see if it's not being shorted this can also cause the board not to boot pluse check ram sticks making sure they are well seated and clean the cntacts from dirt on the ram sticke if al gose well and still no boot then get a converter and try this if all else fail try a ney cpu if same resaults then replace board.
I have a foxconn 45cmx motherboard with a realtek alc662 sound card. I have alle drivers installed en updated but i have no sound. Can anyone tell me what to do?
Verify that the volume is not set to mute. If possible verify that the Front Audio is disable when it is not connected to the front audio panel. To disable Front audio as below: pin 5,6 and pin 9,10 should be short with jumper.
Nov 02, 2011 | Foxconn 45CMX socket LGA775 motherboard...
I need the driver foxconn motherboard 45cmx it does not work the sound on the motherboard
Hello Dark 616!
Foxconn has drivers for the 45CMX motherboard available for download on their website. The link for your motherboard is 45CMX
Nov 22, 2010 | Foxconn 45CMX socket LGA775 motherboard...
I am having xp Home,board model foxconn 45cmx i cant install audio driver help me
Befor installing Audio install Below update package for audio.
then install Audio Driver
http://download.cnet.com/kb888111-exe/3000-2110_4-104699.html
i think it solves u r problem
RATE ME!
Jun 27, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Problem with foxconn 45CMX onboard drivers
GO to your Start menu and click on microsoft updates and when it pulls up internet explorer click on the tab that says hardware and check the box and it'll install the drivers for you
Jun 16, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Find sound driver for foxconn 45cmx
doun load from net and install or use dark edition oprating system on full version option 5
May 31, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Built in Soundcard not work for Foxconn 45CMX motherboard
have u installed the Sound Driverr.If not install it Frm here download new drivers .Click on link.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0002031
install/restart it should work if not Reply with the Error Code.
May 16, 2009 | Foxconn 45CMX socket LGA775 motherboard...
I have the same problem, solved it partly by downloading from the Realtek site, some drivers. Now the sound is OK but still the ethernet lan controller doesn't work, neither the pci modem.
Thanks and good luck!
pema rinchen.
Oct 21, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
200 people viewed this question
Top Foxconn Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
