Question about AOpen MK77M II (91.88D10.016) Motherboard
Memory hi i am trying to find out how much memory i can put in this motherboard . there are 2 slots for ddr memory 512 each or 1gb each slot . thank you email add. is tricountywindows@yahoo.com
  • 6,487 Answers
The maximum RAM or memory that this MOBO can supports is up to 2 GIG so you can go ahead upgrade the memory , check also this link for the information http://www.dealtime.co.uk/xPF-AOpen-AOPEN-MK77M-II-VIA-KM266-CHIPSET-ULTRA-ATA133-MICRO-ATX-FORM-FACTOR-1xAGP-4X-3xPCI-1xCNR-2xDDR-W-INTEGRATED-VGA-LAN-USB-2-0-AUDIO
Hope that helps.........
Posted on Aug 26, 2008
Memory pc3200 ddr 400
With many mobos (motherboards) you must place a single stick in a certain slot in order for the mobo to post. In my Asrock it is the #2 slot for a single stick. If I put it in the other slot the computer will not post. Try moving your stick to the other slot and reboot.
Oct 12, 2013 | Asrock Computers & Internet
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Hangs on testing base n extended memory
appears to be a RAM/Memory Problem.
Or Corrupt Bios.
Try swapping The Memory to different Slots, or try 1 stick in Individual Memory Slots. Also Ensure the Board Has the Correct Ram Installed i.e DDR/DDR 2 et,c.
Mike @ Compurepair.
Nov 06, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Want to improve speed of p.c
if ur motherboard has 2 extra RAM slots...den u can add 2 more ddr rams...They come in 512,1gb,2gb catagories...
May 08, 2009 | EliteGroup K7S5A Pro Motherboard
Memory installation
Most likely, it is a limitation of your motherboard. Not all motherboards or computers can physically read all types of memory or they may have memory limitations. For instance, I was working on an older Gateway this week. It had 2 memory slots but the maximum amount of memory the computer would recognize is 512 MB. Therefore, if I had put to 1 GB sticks in, provided the computer could use it, the maximum the computer would be able to see or use is 512 MB. In this instance, that is most likely the scenario. The best thing to do is to go to www.crucial.com and run the system scanner. It will tell you how many slots you have, what the maximum per slot capacity and the total capacity of your computer is.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Intel Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Aug 23, 2007 | Abit BL7-RAID Motherboard
AOpen MK77M II (91.88D10.016) Motherboard Logo
83 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
