Question about Rainbow 75th Anniversary Canister Vacuum
Dust blown out of Rainbow SE Performance vacuum
I have a used Rainbow SE Performance vacuum and when I use it to vacuum my carpet, it blows out some dust when I push the button to vacuum. While holding on to the button the dust only comes out on the initial push of the button and when I pull back when vacuuming. I hope this makes since. I've already cleaned the brushes and it still does that. Please let me know what needs to be done to not have that happen. I was thinking that there might be a filter somewhere that needs to be changed. Let me know. Thanks.
  • LW May 22, 2012
    Remove bottom plate cover on power nozzle and check for debris obstruction where it chambers into the hose. .... also check the wand and hose for obstructions. Sounds like the brush is stirring up dust, but suction is being prevented by a hair/fiber clog somewhere. . . therefore, it blows out instead of getting sucked up.
Your separator needs to be cleaned
Posted on Sep 18, 2008
    Sergeant:
    Habit-Forming:
  • Rainbow Expert
  • 138 Answers
Good chance there is a clog in the hose and dirt is collecting in the power head. Let us know if that doesn't help...
Contact Us
Posted on Dec 13, 2017
  • 357 Answers
Nan,
There are no filters inside the SE Rainbow. Unfortunately, sometimes Rainbows get all dusty and dirty up inside the main unit and need to be cleaned internally. This service can cost anywhere from $50.00-$100.00, depending on your local vac shop prices.
Posted on Aug 28, 2008
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
How does Aqua Mate attach to Rainbow SE vacuum?
You can download the manual here...
Rainbow Vacuum Manuals
We are also available if needed at Contact Us
RainVac
Jun 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
SE rainbow vacuum break down photos
You are supposed to put water in those vacuums there should be a video on YouTube my mom had one like back in the 80s hope this helps Merry Christmas
Dec 09, 2017 | Vacuums
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I just purchased a rainbow D4C, after purchasing i was told i should have purchased the SE model. whats the difference?
There is only one difference between the D4 and the D4 SE, which stands for D4 (Special Edition). It is the exhaust plug screws in on an SE and snaps in on a regular D4.
Then the SE-PE came along, which stands for (Special Edition-Performance Edition) which has a more powerful motor, with larger motor brushes, for more power and runs on 9.8 amps, where the regular SE and D4 run on 8.8 amps. It also has the newer PN-2 power nozzle, which is very much like the latest E and E2 series Rainbow vacuums, instead of the earlier rectangular ones, that have the bottom metal plate, which will rust. You can upgrade your D4 to one of these, though you will need the electric hose with gas pump style handle, with the built in power corn in it.
They are all D4 models.
Thank you,
Ralph
Apr 02, 2010 | Rainbow 75th Anniversary Canister Vacuum
Rainbow e series musty odor
The unit and the nozzle have to be taken apart and cleaned. You almost for sure will need a new HEPA and possibly even the motor cooling filter. There is a lot of dust inside that got moist (moisture in the air,vacuuming wet carpet, maybe you have pets or everything together)
It will require a bit more advanced skills but you do not have to be a vacuum repair professional to do this.
Sep 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow shampooer and frieze carpet
yes, it can be used without harm, but try a test area to be sure the dye is not cheap
Aug 21, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
May 30, 2007 | Bissell 3522 PowerForce Bagged Upright...
Rainbow 75th Anniversary Canister Vacuum Logo
463 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
