Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Installation of foxconn 45cmx
Can i use a 20 pins power supply wiht the motherboard foxconn 45cms?
    President:
  • 2,351 Answers
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Posted on Aug 26, 2008
Why there is no power of foxconn motherboard g31
Many potential reasons--unfortunately including motherboard DOA, mem DOA, CPU DOA.
Sometimes, even a mere bum PCI-E I/O card will halt function completely, too! Removing such a card may restore nominal function.
Is the heatsink installed correctly--with the correct amount of thermal paste? Is the fan connected to the motherboard fan connectors? Is the secondary power connector from the power supply connected? It's the power connector which fits a special motherboard socket of 4 or 8 pins--that's in addition to the main connector with 20- or 24-pins. (This is not a high-powered PCI-E video card dedicated-power connector!)
Jul 17, 2014 | Foxconn Computers & Internet
I have a foxconn 45cmx motherboard with a realtek alc662 sound card. I have alle drivers installed en updated but i have no sound. Can anyone tell me what to do?
Verify that the volume is not set to mute. If possible verify that the Front Audio is disable when it is not connected to the front audio panel. To disable Front audio as below: pin 5,6 and pin 9,10 should be short with jumper.
Nov 02, 2011 | Foxconn 45CMX socket LGA775 motherboard...
I need the driver foxconn motherboard 45cmx it does not work the sound on the motherboard
Hello Dark 616!
Foxconn has drivers for the 45CMX motherboard available for download on their website. The link for your motherboard is 45CMX
Nov 22, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Can i use 5.1 audio with foxconn 45cmx onboad audio. i'm using windows 7. they only display stereo on audio channel settings on sound configuration at control pannel.
You should be able to, you may need to download and install Win7 compatible audio drivers for your motherboard. You should be able to find those at the Foxconn website. Follow links for support and downloads.
Nov 11, 2010 | Foxconn 45CMX socket LGA775 motherboard...
I need to get the power connection wires for foxconn n15235
wires should be on the tower,were they go should be on the board.
there probably know where near the acctual pins,look all over the board with a tourch.
forget that here download the manual
Sep 30, 2010 | Foxconn 45CMX socket LGA775 motherboard...
I am having xp Home,board model foxconn 45cmx i cant install audio driver help me
Befor installing Audio install Below update package for audio.
then install Audio Driver
http://download.cnet.com/kb888111-exe/3000-2110_4-104699.html
i think it solves u r problem
RATE ME!
Jun 27, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Problem with foxconn 45CMX onboard drivers
GO to your Start menu and click on microsoft updates and when it pulls up internet explorer click on the tab that says hardware and check the box and it'll install the drivers for you
Jun 16, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Find sound driver for foxconn 45cmx
doun load from net and install or use dark edition oprating system on full version option 5
May 31, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Built in Soundcard not work for Foxconn 45CMX motherboard
have u installed the Sound Driverr.If not install it Frm here download new drivers .Click on link.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0002031
install/restart it should work if not Reply with the Error Code.
May 16, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Troubleshoting on installation of mb foxconn 45cmx
have you placed the 4 pin block to the motherboad and also check the bois clr jumper to see if it's not being shorted this can also cause the board not to boot pluse check ram sticks making sure they are well seated and clean the cntacts from dirt on the ram sticke if al gose well and still no boot then get a converter and try this if all else fail try a ney cpu if same resaults then replace board.
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
326 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
