Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool "Duet" Frontloader washer
We have a front loading Duet that is 4 years old, and up until now has worked flawlessly. Over the last couple of days, it seems the end of cycle spin would not completely spin off the water, and when the load was finished, the clothes would still be wet. Went out to look at the washer this morning (after a day of non-use) and discovered that the tub was nearly full of water to the point of exiting over the door threshold. So... I checked the drain... and no back flow from there (the water was fresh), and I don't think it has anything to do with the water pump, but I did notice that the water supply point inside the door showed evidence of water streaming in albeit at a slow rate. My guess is that there is some kind of water control valve, that provides a pre-determined amount of water to each cycle, that has failed. Please advise. Thanks!
  • Sarnt Aug 26, 2008
    Ngfam...
    Thanks for responding, and based on what information I provided, I'm grateful that I'm at least on track. May I ask one additional question? How likely is it that there may be some other key piece of hardware that has failed thereby giving the same sort of indicators? And do I really need factory service??! Or was this more of a solicitation than a solution? Regardless... your time investment is duly noted. Thanks again.
    Sarnt.
  • kmsd Aug 26, 2008
    I too have recently run into the same problem. My Duet is only 3 years old and I've had nothing but praises for this wonderful appliance! Imagine my surprise yesterday when I opened the door to the washer and found water sitting in the drum after a day of non-use. As mentioned, the water was clean and I decided to check the detergent/Bleach dispenser. I noticed that water was streaming from the back side of the wall at a slow pace but leakig nonetheless. Thanks for your suggestion as I will be contacting someone locally for service. Any idea how much the replacement part cost??
    President:
  • 1,294 Answers
The freshwater leak is a simple fix. After plugging off the wall, check the inlet water valve electric connection to see the harness has come loose. If there is no problem there you only have the change the inlet valve which you can do yourself. Check model number and try the sites below for spares.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 11, 2009
  • 639 Answers
Dear sarnt,
ngfam at you service!
You are correct there is an automatic water control that sets the water level buy weight!
When you get an error its best to call service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
  • Neil
    Neil Aug 26, 2008
    Dear friend,
    I do not work for them or have any vested interest in their repair service!
    I am the sales manager of a family owned appliance store that is over 65 years old!
    www.nastasisfurniture.com
    30,000 sq ft of furniture and!!!!!!!Appliances was grandfathers first product back then!
I have a whirlpool duet frontloader. Last week I noticed that it would stop in mid cycle and not finish. I would start the cycle over to finish the cycle and it worked a couple of times and now it will...
I believe you have a drain pump issue. Try removing the bottom front panel on your washer ,three small screws right at floor level. the drain pump will be right their in the middle up front.. lay down some towels or a pie pan to catch some water,remove the cap on the end of the drain pump. Clean out the cap/strainer and remove any visible gook in the pump,line up the marks on the cap and pump and reinstall..hopefully it was full of junk and your ok now, sometimes though the impeller in the pump gets damaged and it will run but not pump even if you have to replace its an easy fix Good Luck
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I tried to start a load and an F-1 code flashes. I have a Duet Sport front load washer (2 years old).
Go to the Whirlpool webside and download a manual for free. They are good folks.
Here is mine...
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
G.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do we fix the washing machine when it says, system locked
unplug for a minute then plug in or turn circuit off for a minute and back on. It worked for me.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet frontloader only washes with hot water. Cold water is turned on and the button for cold is lit. Any help?
The cold water control valve may be bad. Switch the hoses to test the control valve. The valve is not too expensive, and should not be too much trouble to change. If your hoses are over five years old, replace them too, a burst hose is an awful thing.
May 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an F1 error message on my new Whirlpool Washer
Is this a whirlpool frontloader if so you have a faulty control board it's located under the lid. you can remove with 3 bolts 1/4 " socket . and the board is located on the front right side
Jan 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The fabric softner does not empty
its a whirpool    frontloader duet its says 6f dont kniw what it mean
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
prem mathew
