Question about Gateway FPD2275W LCD Monitor
How to disassemble 900w
How do you disassemble the Proview 900W monitor ?? I removed the base stand and took out the four screws along the bottom. The bottom has a lot of play in it but the sides don't wanna budge. Are there some hidden screws or is it a snap-lock type setup ?? This has the same blank screen symptoms as the pl916s so I'd really like to get a look at those caps.
Thanks for any help.
    Novelist:
  • 159 Answers
The proview trims have to be slid upwards to remove them once the 4 screws are out of the bottom.
You'll need to lift the top part slighty away from the lcd to allow the sides to slide up.
If you don't slide it , then yes, you'll break tabs.
ebays bammbammfran
Posted on Oct 10, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Gateway Master
  • 848 Answers
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0088 Proview 860 ALZ M713W Power Supply for PL916S
Posted on Nov 30, 2014
Ok y call your company ,from quebec and the ladie transfer my too sombodey the person dont want too help me ,im realy desapointing about your service...y call too order a powers suply for my MONITOR number is LT926W...model900W serial F)SUC081782 C y want to order the power suply number made by MIRAGE ELECTRONIC CO LTD number PI 190 DTLBH VERSION A watt did y have to doo . to get that part please give à call abot that 1-514-510-5321 Claude Parent any time .y like too recive a call from you thanks you
Posted on Jan 09, 2009
After removing the four screws (rear of monitor, along bottom edge) then the front bezel can be
removed from the rest. It's a "snap-together" affair, and it's not too easy to get. Suggest try starting on the sides then the bottom. I wasn't able to do this without breaking some of the snaps, oh well.
Posted on Sep 24, 2008
removed from the rest. It's a "snap-together" affair, and it's not too easy to get. Suggest try working on the sides then the bottom. I wan't able to do this without breaking some of the snaps, oh well.
    Brigadier General:
  • 5,158 Answers
I had a bear of a time with a benq monitor. Remove whatever screws you can see on the base where it attaches to the monitor. You need to lift up the metal bracket past the lip of where it slides into as you are moving it away from the monitor.
Robert
Posted on Aug 29, 2008
My monitor will not come on. the powere botton is flashing blue
Which model 900w or LE1936 ?
This info is usually on a sticker to the side of the stand.
If the 900w: You problem is probably that the capacitors on the power board have gone bad and need replacing. May also have transistor problems.
You would have to open it up to get a better idea.
I can probably tell from a picture.
If it is the LE1936: then it could be a similar capacitor problem, but it is rarer on this model than the 900w
Also on this model, there is a voltage regulator on the vga-dvi board that tends to go bad.
email bammbamm@ptd.net
Nov 03, 2010 | Gateway FPD1975W 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I have a proview monitor PL926WBI Model 900W
It seems to be that something gets hot inside after a few minutes of operation of the monitor. So I placed a small fan so that air flows thru the monitor and that did it. What gets hot inside , I don't know.
Oct 25, 2009 | Gateway FPD 1510 15.1" Flat Panel LCD...
I have a proview 900w and it comes on but only for a couple seconds then the backlights turn off. Does anyone know how this might be fixed?
check your signal cable from your computer or the port itself. one of those might have a problem causing the monitor to go off.
thanks
wonder
Sep 18, 2009 | Proview PL926WBi 19" LCD Monitor
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Proview 900 series black flat panel monitor
its sound you have bad inverter chip. The I.C. "BIT3193G" is the main controller in the inverter circuit. This chips is a surface mount chip and you must be careful remove it or you can damage the board. Also have you check for any burn out transistor?
Feb 21, 2009 | Computers & Internet
Proview 900w
this prob is memory is in monitor so contact sevice engg of proview
Dec 11, 2007 | Proview PL926WBi 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
2,045 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
