Question about Dell Dimension 8400 PC Desktop
Your Dell 8400
Did you ever get your dell fixed. I have the exact same problem where it wont start - fan full blast, screen off. no abcd lights on. I can only get it working by plug/unpluging it many times.
Please reply to spidelle@netzero.net
Edward
  • Anonymous Nov 06, 2008
    Exactly the same problem, Dimension 8400 from September 2004.
    When it starts, all POST lights remain dark, have amber power light, and in several seconds the fan begins revving up like a plane taking off. If I press power for 5 seconds, that turns the PC off. The blue LED on MB stays lit as long as the PC is plugged in. I measured the power taken by the PC, and it increases up to 240W while the fan revved up, so something is taking plenty of power. However, nothing feels hot...
    I saw bulging capacitors on the MB (orange Nichicon, 5 x 1000 microfarad and 1 x 2200 microfarad - and replaced all of them). Checked the P/S for bad capacitors but all are visually OK. Hope this helps.
  • 27 Answers
If you have a power surge or surge protector, bypass them and connect it directly to the wall socket, check if the issue is the same
Posted on Feb 07, 2009
  • 3,940 Answers
The fans running full tilt indicate a NO POST condition, normally a motherboard failure
Posted on Jan 25, 2009
Dell dimension 8400 won't turn on
Sounds like you might have a Bad Processor, Take it to a shop, don't tryh to fix this one yourself
Mar 11, 2012 | Dell Dimension 8400 PC Desktop
Dell 8400 dead
Can you tell if your hard drive is running? You can here it or feel it spinning. Are the fans running? If no, I'm 99% sure you need to replace your power supply and/or motherboard. This kind of thing usually happens after a power surge.
Sep 24, 2007 | Computers & Internet
Cpu fan fast bios wont start
Run the Dell Diagnostics to test the Fan.
Check to make sure the fan power connector is connected to the mother board.
The fan could be defective.
Reset BIOS to factoiry default settings.
I hope this helps.
Good luck and have a pleasent day.
May 16, 2011 | Dell Dimension 8400 PC Desktop
I have dell optiplex gx280 computer.i am facing problem of CPU high fan speed when i turn on the PC.it goes to full noise like a jet fighter and nothing get appeared on the screen and fan continuously gone...
dells usually go full blast on power up then slow down to normal,sounds like fan is not responding to slow down signal i would try replacing fan, its got to be a dell fan
Jan 08, 2011 | Dell Optiplex GX280 (99301) Motherboard
Dell dimension 8400 will not start.
no man try to take out the modem ( last pci slot on the botom of the board) and see if you have any luck if not you going to need a new motherboard thanks and good luck
Oct 11, 2009 | Dell Dimension 8400 PC Desktop
Dimension 8400 will not boot and more.......
I would recommend testing the power supply as Dell PS's are not known to be "forever". A power supply tester can be purchased online at Tigerdirect.com for around $20 and they are fairly easy to use (you can also get a new PS there if necessary). If that is not it, I recommend going to a local small computer shop and picking up a used Hard Drive (be sure to get SATA), and switch it for your main HDD,, if the PC starts up and goes to an "Error no OS found" or the ilk, the culprit is your hard drive. I am in CT and fix PC's for a living, I am A+ certified and have passed all the dell Factory Cert tests. If you need help and are in the area or work well over the phone,, let me know I CAN solve this problem.
Jim
Aug 04, 2009 | Computers & Internet
Dell Dimension 8400 Start up Fan Noise
Might be a hard drive issue. I had the same problem with one of My desktops. I replaced the hard drive and it worked fine.
Jul 01, 2009 | Dell Dimension 8400 PC Desktop
Dell 8400 runaway fan no diagnostic lights and very ocassionally it starts normally
Which fan?, the cpu fan or the cpu fan?
Most Dell pc come with a below average power supply. I recommend replacing your power supply with a better one. Do a search on Google for a good replacement power supply for you Dell 8400.
Please rate response.
Feb 17, 2009 | Dell Dimension 8400 PC Desktop
Woes with Dell
If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
Disconect fan , see if it starts.
Jan 13, 2008 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
193 people viewed this question
Alun Cox
