Question about HP D8597A Keyboard
Delete key when i use the delete key, my caps light comes on and the microsoft assist window opens with out deleting the desired charactor. after a second attempt, the microsoft save as box opens and further subsequent attempts only result in other windows unrelated boxes and windows to open. this happens not only in MS WORD but Works and any time the dlete key is attepted to be used. the only way I can delete anything is either to reposition the curser with the mouse and backspacing or via menu selection. I have tried everything short of a ball peen hammer to fix this problem
  • jimmyjam17 Sep 07, 2008
    more on this problem, turns out not to be a software problem but hardware. after playing around with the computer I noticed the screen to have a little play at the hinges. If i pushed slightly on the screen the problem was evident, if i pulled the screen toward me with very little force the the problem ceased. I lifted the hinge cover at the base of the screen and tightened the hinge screws on both sides and that did the trick. who would have thunk it. thanks to those who gave me input
  • 1,586 Answers
It sounds as if the keyboard is shorting out internally. With the cost of keyboards so low (many times under $10), it's not really worth troubleshooting it very long or hard - a better fix likely is to just buy a new keyboard.
Posted on Aug 26, 2008
My storage is so full I am scared to get the fix it app
Hi, I Suggest not do delete Windows Defender and its now default antivirus/firewall provided by Microsoft. If you still want to delete it please do follow the below process to un-install manually.
1. Open a command Prompt and type the following to stop and then delete the Defender service:
  • type in : sc stop windefend and press enter
  • type in : sc delete windefend
2. Next you need to grant full permissions to and delete the following registry key so the Defender Control Panel entry can be deleted: open RUN command and type in regedit
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\{D8559EB9-20C0-410E-BEDA-7ED416AECC2A}
3. Also grant full permission and delete the Defender program registry key:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Defender
4. Now take ownership of and delete the following folders:
  • C:\Program Files\Windows Defender
  • C:\ProgramData\Microsoft\Windows Defender
  • C:\Program Files (x86)\Windows Defender (for 64-bit users only) and reboot the computer.
Nov 08, 2017 | YouTube Computers & Internet
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore...
Windows XP HELP
  • Windows key + R = Run menu
  • cmd = Command Prompt
    iexplore + "web address" = Internet Explorer
    compmgmt.msc = Computer Management
  • Windows key + E = Explorer
  • ALT + Tab = Switch between windows
    ALT, Space, X = Maximize window
    CTRL + Shift + Esc = Task Manager
    Windows key + Break = System properties
    Windows key + F = Search
    Windows key + D = Hide/Display all windows
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
  • Keyboard Shortcuts
  • [Alt] and [Esc] Switch between running applications
    [Alt] and letter Select menu item by underlined letter
    [Ctrl] and [Esc] Open Program Menu
    [Ctrl] and [F4] Close active document or group windows (does not work with some applications)
    [Alt] and [F4] Quit active application or close current window
    Ctrl] Lft., Rt. arrow Move cursor forward or back one word
    Ctrl] Up, Down arrow Move cursor forward or back one paragraph
    [F1] Open Help for active application
    Windows+M Minimize all open windows
    Shift+Windows+M Undo minimize all open windows
    Windows+F1 Open Windows Help
    Windows+Tab Cycle through the Taskbar buttons
    Windows+Break Open the System Properties dialog box
    explorer shortcuts
    END....... Display the bottom of the active window.
    HOME....... Display the top of the active window.
  • Type the following commands in your Run Box (Windows Key + R) or Start Run
  • devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    control = Opens the Control Panel
  • Internetbrowser
  • type in u're adress "google", then press [Right CTRL] and [Enter]
    add www. and .com to word and go to it
  • For Windows XP:
  • Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Refresh the active window. F5
    Cancel the current task. ESC
    on Oct 12, 2010 | Computers & Internet
    How do I delete from my favorites
    The following document contains information on how to manage your bookmarks and favorites in all of the major Internet browsers. To proceed, select your browser from the list below and follow the instructions.
    - Internet Explorer
    - Google Chrome
    - Mozilla Firefox
    - Opera
    Internet Explorer
    To access favorites:
    Press Alt + C
    or
    Open Microsoft Internet Explorer.
    Click on the Favorites IE favorites icon in the upper right-hand corner of the browser window.
    Click any Favorite folder to expand and show its contents.
    To delete favorites or folders:
    - Right-click the favorite or folder you want to delete.
    - Select Delete from the drop-down menu that appears.
    To move and organize items in your favorites:
    - Drag-and-drop your favorites or folders to rearrange them.
    Renaming items in your favorites:
    - Right-click the favorite or folder you want to rename.
    - Select Rename from the drop-down menu that appears.
    - Type in the desired name and press Enter.
    Google Chrome
    To access your bookmarks:
    Press Ctrl + Shift + O
    or
    Open the Google Chrome Internet browser.
    Click Customize and control google chrome Chrome settings in the upper right-hand corner of the browser window.
    Move you mouse cursor over Bookmarks and then click Bookmark manager.
    Deleting:
    - Highlight the bookmark or folder you want to delete by clicking it once.
    - Press the delete key on your keyboard to remove the bookmark or folder.
    - Tip: You can also right-click a bookmark or folder, then select Delete from the menu.
    Organizing:
    - Drag-and-drop your bookmarks or folders to re-organize them.
    Renaming:
    - Right-click the bookmark or folder you want to rename.
    - Select Edit... from the drop-down menu that appears.
    Mozilla Firefox
    Press Ctrl + Shift + B
    or
    Open the Mozilla Firefox Internet browser.
    Click Show your bookmarks Firefox bookmarks in the upper right-hand corner of the browser window.
    Select Show All Bookmarks.
    Deleting:
    Organizing:
    Renaming:
    - Highlight the bookmark or folder you want to rename by clicking it once.
    - Locate the field labeled Name: in the lower right-hand section of the Library window.
    Opera
    or
    Open the Opera Internet browser.
    Click Customize and control Opera opera button in the upper left-hand corner of the browser window.
    Select Bookmarks from the drop-down menu that appears.
    Deleting:
    - Locate the folder or bookmark you would like to delete and move your mouse cursor over it.
    - A circled X should appear in the upper right-hand corner; click it to delete.
    Organizing:
    Renaming:
    Apr 08, 2017 | GPS
    I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
    You can uninstall printer driver from library folder.
    Go to system preferences and delete driver from Library /Printer .
    Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Feb 20, 2010 | Computers & Internet
    Help plsss
    Just insert the original seriel key
    1. Download Windows Product Key Update Tool (KeyUpdateTool.exe) from Microsoft.
    3. Enter the product key found on your COA where requested, and then click Next to begin the update. toolscreen2_en.jpg
    4. Once the update is complete, click Finish to restart your computer. When your computer restarts, your computer’s product key will match the COA product key. If this tool fails to change your product key to match your COA, contact Microsoft Support. toolscreen3_en.jpg
    5. After updating your product key you will be required to activate Windows. Once Windows is activated, you can verify that your copy of Windows is genuine by going to http://www.Microsoft.com/genuine and clicking Validate Window
    Feb 05, 2010 | Microsoft Windows XP Professional for PC
    How can i fix m3plugin .dll error
    Do the following step and get rid of it.
    Open Run , type regedit and press enter
    Go to
    HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
    and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
    In Regedit go to;
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    and delete any value except "Default".
    then go to;
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    and delete value except default and anti virus.
    Best of luck.
    Hasan
    Dec 05, 2009 | Intel Motherboard
    Outlook express
    Are you using Outlook?
    open Outlook, then click on help, then on drop down menu, cick on "detect and repair"
    If that does not work:
    Go to :
    Start
    Control Panel
    Add/Remove programs
    when the windows opens up , scroll down to MS Office, then click on change.
    A window will open and the second choice should be "repair" You may need to have your MS Office handy.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Oct 12, 2008 | Microsoft Office Standard for PC
    Calender problem!
    To add, change, or delete a Calendar appointment from the handheld, follow these steps: To add an appointment
    1. From the Home screen, press the Menu key.
    2. Scroll to and select Calendar.
      • NOTE: To select, press the trackball.
    3. Scroll to and select desired date and time.
      • NOTE: Selecting exact date and time will default to that date and time when the appointment opens, however these fields can be changed so any date and time can be selected.
    4. Enter a Subject.
    5. Enter a Location.
    6. If desired, select All Day Event.
    7. If desired, scroll to and set the Start and End date and time.
      • The 'Duration' should update accordingly.
    8. Scroll to and set Time Zone as desired.
    9. Scroll to Show Time As.
    10. Select one of the following as desired:
      • Free
      • Tentative
      • Busy
      • Out of Office
    11. Scroll to and set Reminder time as desired.
      • The options range from None to 1 Week.
    12. Scroll to and set Recurrence as desired:
      • None
      • Daily
      • Weekly
      • Monthly
      • Yearly
    13. If desired, select Mark as Private.
    14. If desired, select Notes, then type any notes.
    15. Press the Escape key.
    16. Select Save.
    To change an appointment
    3. Select the appointment to be changed.
    4. Adjust any options as desired.
      • NOTE: The available appointment options are listed in the portion above.
    6. Select Save.
    To delete an appointment
    3. Select the appointment to be deleted.
    4. Scroll to and select one of the following:
      • Open the series (for reoccurring appointments)
      • Open this occurrence
    5. Press the Menu key.
    6. Select Delete.
    7. Select Delete again to confirm.
    I would recomend that you powercycle your phone regularly. If you have anymore questions feel free to ask me.
    Apr 25, 2008 | RIM BlackBerry Pearl 8100
    HP D8597A Keyboard Logo
    77 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
