Question about HP OfficeJet 7410 All-In-One InkJet Printer
Paper tray selection- printing
Upper paper tray pulls paper in at an angle vise straight and lower paper tray selection will not engage prompts says out of paper when the tray is full and the guide is tight against the paper
    Sergeant:
  • 399 Answers
Its the problem of the sensor which detects the paper in the tray.either it is moved from its orignal position or its broken.so this problem is coming.
thanks.
Posted on Sep 18, 2008
Only prints from the MP feeder and not through tray 1 anymore
if your printer only prints from the mp tray this is saying that it no longer recognizes tray one.
the first thing to check is the paper size fingers on the side of the tray. pull the paper tray all of the way out of the printer. there is a snap in plate on the left side of the tray. for letter size paper 2 fingers should be sticking out. if the fingers are present and not broken off. look into the opening that the tray was removed c
from on the left side half way back there will be 4 metal tabs make sure these are even and straight. if both of these are not damaged.remove the logic pack (metal cage behind the left side cover. loosen the 6 screws and remove the out cover. on the inside of this box remove the screw located upper right hand corner, remove the screw in the lower right corner, and the screw from the upper left corner. now one more screw on the back of this box lower left corner remove this screww then pull up on the box and set it aside. at this point you will see the main motor drive in the middle of this side dierictly under the motor you will see a small pcb that is attached with 2 screws ramove these and rfeplace this board it is the paper size select pcb and it needs replaced
Jan 06, 2011 | Lexmark Optra T610 Laser Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
I am trying to print onto 5.5w x 8.5h invitation paper. What settings do I need to use? If I select the paper size and put it in the printer, it will not print .... expecting regualar size paper.
Have you tried the upper level tray of your printer?
Go to the Print command
Select Properties
Go to paper source
Select upper tray (Be sure tray is loaded with paper)
select OK,
select OK
Jul 14, 2009 | HP PSC 950 All-In-One InkJet Printer
HP Deskjet3845
To remove the jammed sheet of paper :
1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out. CAUTION! The paper may be covered with unfused toner, which can stain garments.
6. If you see no paper jammed under the cartridge, remove paper tray 1. The paper may not have fed all of the way into the printer.
7. Reinstall the paper tray and the toner cartridge.
8. Close the upper front door.
Mar 11, 2009 | HP Deskjet 3845 InkJet Printer
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
Loading A5 paper into photosmart 8450
your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
cheers
Sep 27, 2008 | HP Photosmart 8450 InkJet Printer
Tray selection
If there is such a thing for that printer it would be in the advanced settings under you printer driver.
Select control panel.
Select printers.
Move the mouse over to the printer.
Press the right mouse button.
Select properties.
Press the printing preferences button
Look under the advanced tab for the settings.
You could see if there is an updated driver on HP.com if that feature isn't listed.
Jun 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
104 people viewed this question
Ben Johnson
