Question about Technics SL-1200MK5 Turntable
Technics Table spins left and right in the on position
My Table just started randomly spinning left 3 inches then back right 3 inches in the on position.  It will do this back and forth until i press the start button.  Then the table works perfectly and spins like normal with no problems.  Please advise!!!!  Any help would be appreciated
Thanks
  • 515 Answers
You have an issue with your drive circuits. Only a service tech can diagnose and repair this. It's not easy.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
I took out all discs. When I tell it to play a disc the table moves back and forth slowly about an inch. After a couple trys "Table Error" shows up. Both belts are old but on.
Tray will prolly need retimed after the belts slipped off the pulleys.
Procedure is with tray brackets removed lift tray in back then push open button to let the cam gear spin around to open position. Then let tray down and try to close it with button. Reinstall brackets and may take a few attempts to get that gear in the right position!
Dec 16, 2014 | Sony CDP-CX300 CD Player
Why douen't my technics turntable spin?
Take off the rubber mat and see if the belt is off the aluminum platter the record sits on you should be able to see the rubber belt when the mat is removed. If it is not there or broke it will need replaced.
Apr 23, 2013 | Technics SL-BD20D Turntable
Breaker trips after two seconds
Could you explain the problem a little more for me? Does it run OK on start up and when you go to cut you have the problem?
Oct 25, 2011 | Powermatic 1660802K Model 66 Special...
Technics SL-DZ1200 Turntable Wont Start Up
Hi Derrek,
I have exactly the same problem, I was wondering if you have found a fix for it? I have to cut the power 2 or 3 times before it starts up and then it seems to work perfectly! Very strange...
I would really appreciate any help,
Many thanks,
Fred
May 08, 2010 | Technics SL-DZ1200 Turntable
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
I have a SL-B30 that when turned on won't start up.
if your model does not say "direct drive" on the front then it sounds like your belt came off. this video will show you how to put it back on
http://www.archive.org/details/Turntable_Belt_Installation
Feb 15, 2009 | Technics SL-1210 Turntable
Porter cable beffer
Check for string or build ups where the spindle come out of the housing, a little light oil at that point will help, 3-in 0ne is good, not to much, a little goes a long way
Jan 02, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Technics SL-1200MK5 Turntable Logo
147 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
