How do I program a 1987 rca tv, lost the remote for it
I can not see the writing on the 5 buttons in the front of the tv when I try to program it, the tv reads A01, A02, etc... it ends up on channel 60. I have it connected to cable (yes, it is in the right hook up in the back and the button in the back is on cabtv
  • 3 Answers
How do I program the remote to the tv
Posted on May 07, 2012
If it is xl-100 "remote control" model (manu. 1987) I have a drop down door on front, there are names for buttons (5) at left:
auto pro,
step<
step > (arrows actually up/down)
add
erase
The other buttons to R are channel up & down, volume up & down & red Power, of course.
On the left, if you can "add" in some channels you scroll by, you may get more than 60.
(is this all moot, in 34 days, Feb 17)
My remote for another RCA does work some, for this "oldy."
Posted on Jan 14, 2009
I have an RCA RCR312W remote and lost my manual, request the steps needed to program my JVC tv / I have the codes, just need to know the steps to take ... Thank you
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
Thank you
Jan 16, 2011 | RCA RCR311B Remote Control
TRYING TO PROGRAM REMOTE IT IS A RCA REMOTE LOST INSTRUCTIONS TO REMOTE.
HI, Direct Code Entry:
Code Search: 1. Turn on the device you wish to control.
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 08, 2010 | RCA Universal Remote Control
Lost the manual,i don't know what steps to take to program my rcr412bn remote? to my sharp tv.
HI,
Direct Code Entry:
1.Press and hold "CODE SEARCH".
2.Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3.Enter the 3-digit code number.
4.Release "CODE SEARCH".
With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5 with other codes.
follow the below steps to set remote with out codes
Code Search:
1.Turn on the device you wish to control.
2.Press and hold "CODE SEARCH".
3.Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5.Press ON/OFF repeatedly until the device turns off.
6.When the device shuts off press and release ENTER.
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Thanx
Jul 26, 2010 | RCA Universal Remote Control
Lost my manual - need tv codes - ge universal remote - tv to program is a rca xl100 remote
Hi! The code of a GE Universal remote for a RCA TV are 0031, 0004, 0048, 0054, 0094, 0100, 0102, 0107, 0129, 0191, 0005, 0009, 0000, 0162, 0163, 0342, 0003 ,0015, 0022, 0096, 0113, 0125, 0179, 0187, 0188. In case none of these works for your TV you can try these steps for you to program your remote conrol.
1. Manually turn on the TV.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired TV button. The red indicator blinks off once.
4. Press the ON-OFF button repeatedly (up to 300 times) until the TV to be controlled turns off. The red indicator blinks off with each button press.
5. Press and release ENTER to install the code.
Jun 14, 2010 | GE JASRM24912 Remote Control
What is the code for a symphonic tv and a rca remote. I also need insructions on how to program the remote that works with my tv. I lost the instructions
These are the steps on how to program your RCA Universal Remote Control to your Symphonic TV.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV button. When the TV button flashes proceed to the next step.
  3. Enter the three digit code. In your case, the code for the Symphonic TV are 064 or 076.
  4. Release CODE SEARCH.
  5. With the TV on, press another button, for example CHANNEL UP. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-5 using the other code number.
Jun 12, 2010 | RCA Universal Remote Control
I LOST MY PROGRAMING INSTRUCTIONS AND CODES FOR MY TV THE MODEL OF MY UNIVERSAL CONTROL IS RCR4358 ITS A RCA
The code list is located at the following website: http://www.revoxremotes.com/Remotes/RCA_R55L8_Codes.pdf
Find your TV and hold the TV button on the top left. While holding the TV button, enter in a 4 digit code (they should be in the 1000's) - then release the TV button and try the channels or volume up or down
EXAMPLE: TV(1047) release TV button
- try all 4 digit codes associated with your TV
- once the code is entered, try it by clicking channel up or down
- hope this helps, this can be frustrating
- If the remote responds, stop trying codes, your remote is programmed
- WRITE DOWN THE NUMBER FOR YOUR TV WITH A SHARPIE ON THE REMOTE ITSELF THIS WILL PREVENT FURTHER WASTING OF TIME
Feb 06, 2010 | RCA 4-in-1 Universal Remote Control
Lost the manual for my rca universal remote
Try these codes for Quasar TVs:
1003, 1054, 1055, 1070, 1109, 1170
Codes can be found here.
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Basically, try holding the TV button, the on/off button should light up. Then press the digits for the code one at a time. If the code is accepted, the on/off button should go off. Finally let go of the TV button. Now try operating your TV.
Apr 06, 2009 | RCA RCR311S Remote Control
RCA Universal Remote Model #rcr311w
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Jan 11, 2009 | RCA Universal Remote Control
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
RCU410wms RCA Remote
This site will give you the codes;
Enter the codes 1> Press Hold Code Search until light stays on
2> press device button ie.TV
3>enter 3 digit code from site
4>Try Power button, if works great if not try another code
That's It!
Feb 10, 2008 | RCA Universal Remote Control
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
