How to attach the support through the opening in the rectangular ring and pull snug
  • 639 Answers
Posted on Aug 26, 2008
How do you replace sim card,I cant find it.
There is a small 'door' on the side of the phone. Look for a rectangular shape with a small hole at one end. Apple provide a small tool to open it, but you can use an opened paperclip. If you push the end into the whole. then the door will move out. Pull this out, and you will see an attached carrier for the SIM card.
Apr 07, 2016 | Apple iPhone Cell Phones
Cant open boot on my mini cooper s touch pad not working
Lift the back seat. Under the seat you will find a cable with a ring attached. Pull the ring and the boot lid will open.
May 27, 2011 | 2004 Mini Cooper
How to change memory in the nb 305 toshiba netbook
the memory flap is on the underside of the laptop, rectangular in size, about the size of 2 large fingers, open that with a screwdriver, release the catches on the two sides of the ram chip at the same time and it should lift up at a 40 degree angle, pull it out, PUT THE NEW ONE IN AT THE SAME 40 DEGREE ANGLE - OR YOU WILL DAMAGE THE CONNECTORS. make sure it's fitted snugly, then push it down, peace, abz
Mar 30, 2011 | Toshiba Computers & Internet
Door doesn't open
There is an emergency door release tab/pull ring attached to the bottom of the door lock assembly.
The lower access panel can be taken off by removing the screws and then reaching up under the door lock and pulling downwards on the pull ring. Pull down and then you can open the door.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How is the floormat on the drivers side attached to the floor rug? There seems to be two metal rings, one in the floor rug and one in the flloor mat. They are not snaps, just rings How is the mat attached...
There is a small plastic hook attached to the floor that goes through the metal ring on the floormat to keep it in place. the hook's open side should face the back of the car, so just pull the mat towards the drivers seat and it should come loose. No clips or anything, just that one hook and ring.
Feb 13, 2010 | 2000 Toyota ECHO
Key is broken in 316i touring lux 1993 ignition how do we get the barrel out and do we need a replacement steering column also
alot of times a broken key may be removed by a torch tip cleaning file. this can be had at most hardware stores. its rectangular and when opened has a lot of little round files in it. find the file that will fit in to the key slot snugly and push it in then slowly pull it out. this may take some expermintation with sizes and techniche but i have removed a lot of key stubs this way.
Dec 03, 2009 | 1996 BMW 318
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Jun 30, 2009 | GE Energy Star WCVH6260F Front Load Washer
How do I get the fuel pump out of my 1998 Land Rover Discovery. I got the lines off and the black metal ring off, so now what?
You probably need to hammer the pump assembly lightly with a punch or dull chisel. Does it have little ears that it will twist out of. There are usually little raised detents in the ears.
May 09, 2009 | 1998 Land Rover Discovery
Kenmore front load he washer
try to unplug the unit and open the door manually by pulling a plastic ring attached to the door lock.
you can access the ring if you open the top cover of the unit and feel the ring where the door lock is and pull it down.
if you were able to open the door, you can check the clothes and remove the one that was jammed on the door. then test the unit for normal operation.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
