Question about Whirlpool Washing Machines
My washmachine fills up with water on it own - Whirlpool Washing Machines
  • 639 Answers
Dear sarnt,
ngfam at you service!
FLOOD DANGER!!
Yes sounds like you need service QUICKLY!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Feb 07, 2012 | Simpson Washing Machines
The washmachine fills with water but doesnt cycle
Water pressure switch to be tested. Then the controller circuit board.
Apr 02, 2010 | Washing Machines
I have a GE model WHDRE526E1WW washmachine.The complaint was it would not spin. I checked the agitator coupler and the washmachine agitates but won't spin or fill with water. I suspect it may be the...
Try suspecting the tub end of the water level tube being plugged with " goop " so that the washer thinks it is still full of water, thus will not fill or spin. Take the front panel off by releasing the push in clips at the top of the front panel, in the seam where it meets the washer's top. Now, find the tube at the left side of the outer tub and pull it off the tub. Clean it out or cut off an inch (don't do the cutting thing more than one time) and replace after using a thin wire to clean out the tub end of the attachment. To help prevent this from re-occuering, every few months, fill the washer to the lowest setting with the hottest water, no clothes, and several cups of bleach, and run the longest cycle you have (with no clothes, of course). Make sure to rinse out the tub on a higher water level before you wash a load of clothes.
Sep 06, 2009 | Washing Machines
LG WM2487 will not fill with water. ie error code. have done all the checking of plumbing and filters as suggested in manual and on various websites. Could this have anything to do with a sensor?
Yes, its sounds like you might need to replace the cylinoid, that the part that the hot and cold lines hook to the back of the washmachine itself.
Sep 03, 2009 | LG WM2487H Front Load Washer
The washmachine over fills, when its fiilig up it doesn't stop
Hello,Sounds like a problem with either the inlet valve or the pressure switch, the way to determine which is bad... while the machine is filling pull the power plug..if the water keeps filling it's the inlet valve that is going to be bad..if it stops filling it's going to be the pressure switch. The pressure switch is located in the control panel and has a small rubber pipe attached.once you have figured which it is replace it good luck.
If you have any other questions or concerns please feel free to comment again..Mike
Jul 30, 2009 | Kenmore Washing Machines
Maytag neptune shutdown
You need to first check your water inlet hoses & make sure they are not kinked or plugged.(verify by disconnecting hoses & opening to make sure water flows. If ok. Then check for cold water operation at fill valve. If no cold water after a few seconds then the problem is the water fill valve. If this doesn't help. Post findings for further troubleshooting.
Bill
Apr 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washmachine will not fill with water
If the unit is agitating with no water in it, you will need to replace the pressure switch( aka Water level switch) it is located up inside the control panel and has 3 wires and a hose on it.
Good Luck!
Feb 28, 2009 | Washing Machines
Calypso washmachine
you have a flood condition,,or overfill,,we must get rid of the water it seems the pump cant do it,,also it can be tripped or make this display fl if to much suds are in unit ..press stop than cancel and it will clear...than put unit in drain,,if water doesnt drain we have a drain problem that caused the fl error..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
