Question about Olympus Camedia C-740 Ultra Zoom Digital Camera
Settings that must be set before you can use the external flash
Are there any settings on the camera that must be set before you can use the external flash
    Master:
  • 852 Answers
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built- in flash and the Olympus FL-20/FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Posted on Sep 04, 2005
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
Nikon L810 pop-up flash raised but the camera is not detecting the raised flash
You have to set the on board flash you may have external fllash set on even if you reset your camera go to menu then flash/bracketing then TTL set for flash on camera
Dec 24, 2012 | Nikon Coolpix L810 16 Megapixel Digital...
I have been using my Canon 580ex ii with my Canon 5d mark ii. It will not fire at all now. I also tried my old 420 ex speedlite and it will not fire either. But, they both work on my Canon 40d.
You can actually set the external flash not to fire in the menu settings of your camera. Check there or try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Oct 08, 2012 | Canon Speedlite 580EX II TTL Flash
The flashgun doesn't pop up when it should. It remains jammed.
Ok
Its not clear how you are using the camera.
Check the settings on the left. Some settings (Landscape for example will not allow the use of flash)
Set the camera to P,S,A OR M and it will. In Auto it will pop up if it needs it. It It still won't work Look at the menu settings for Flash Mode two settings 1) TTL and the other Manual. I have my D50 set to TTL using the built in flash and manual when using an external flash mounted in the shoe.
Hope this helps
Dec 12, 2009 | Nikon D50 Digital Camera
Manual light & exposure settings
if you are using flash lights on the art work, please follow the following steps
  1. turn off your flash in cam since it bypasses the external flash and makes the picture look different.
  2. turn your light settings to either automatic or "flash light or arc light".but do not set them to incandescent light!!!
  3. turn your macro to on status if you are going to take a close up shots, but please note that close up shots work great in natural sunlight than at flash lights...
Sep 13, 2009 | Fuji FinePix S2000hd Digital Camera
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Flash Problem
First step would be trying to reset all defaults, which I'd imagine is in the setup menu. Make sure you are also not in a mode which turns off the flash. For the 990 at least these are: The built-in flash will automatically be set to ?Off? when: ? you use autofocus with a setting of ?Infinity? ? you choose a multi-shot setting of Continuous, Multi-shot 16, VGA Sequence, or Ultra HS (an external flash can still be used with these settings) ? you choose a multi-shot setting of Movie ? you use best-shot selection (BSS) ? you use lens converter (LENS) settings ? the AE Lock option in the EXPOSURE OPTIONS sub-menu is on make sure your batteries are fresh and fully charged. if nothing works, consult a professional on repair, use an external flash, or use it just when the sun is out... Good luck!
Sep 19, 2005 | Nikon Coolpix 2000 Digital Camera
Can the internal flash be disabled when using externally attached flashes?
t is my understanding that you must use manual exposure (shutter and aperture) with an external flash. This shouldn't be a problem (set the camera to the settings on the guide chart that comes with your flash, and let the flash worry about the strength/flash duration necessary - provided it is an "auto" flash with a sensor)... I'm going to use a Vivitar 273 with my Epson 3000z... There are a few other threads on this forum regarding External Flash use.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Settings that must be set before... the external flash feature
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-20/FL-40/FL-50 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Any settings that must be set before you can use the external flash feature
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Olympus Camedia C-740 Ultra Zoom Digital Camera Logo
526 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
