Question about Fuji FinePix S3100 Digital Camera
Auto bracketing Does anyone know if the auto bracketing requires you keep the button depressed, or does it take all three during one exposure
    Master:
  • 425 Answers
I'm not familiar with your camera but I know on the cameras I've used in the past that you have to keep the button pressed until all shots have been taken. I believe that some cameras can be set up to take each bracketed exposure each time you press the shutter button but I haven't come across this as yet.
Posted on Sep 04, 2005
Bracketing with a Nikon L105
Well, in a word, no. However the camera does have exposure compensation (multi function button +/- and adjust the exposure compensation up or down) but the camera is not "smart" enough to give you the + and - effects of auto bracketing found on the more advanced Nikon cameras...I believe the D5100 is the least expensive in the Nikon lineup with feature. Good luck.
Dec 10, 2013 | Nikon Coolpix L105 12.1mp 15x Optical Zoom...
Knocking noise when shredding paper
Cross-cut shredders require monthly oiling of the cutting cylinders to maintain proper operation. Failure to oil the blades regularly could result in excessive noise during operation.
Oiling Your Shredder's Cutting Blades:
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three times.
I hope the above helps....
Good luck.
Apr 13, 2011 | Fellowes DM8C Cross-Cut Shredder
I have a 36 exposure film in the camera with 25 pictures taken and I want to remove the film without taking more photos. How do I rewind?
To rewind the film mid-roll, press the two film rewind buttons simultaneously for one second. The two buttons are marked with a red film symbol, and double as the Auto Exposure Bracketing button to the left of the viewfinder and the Aperture/Exposure Compensation button to the right of the control panel.
The film is completely rewound when a blinking "E" shows in the control panel.
Sep 08, 2010 | Nikon F65 35mm SLR Camera
HOW TO SET UP THE D80 FOR HDR
Page 140 of your manual "Bracketing Programs" . This camera seems only to be able to do a 3 frame bracket. Normal , Over , and Under exposure. Set the auto bracket to (3) frames, set a 2.0 bracketing increment the order is not really that important. Normal however should be your first frame shot. Make sure that only the speed changes in the different exposures not the aperture this would lead to de-focused images. One you have the three images you will have to bring them into ©Photoshop or ©Photomatrix Pro to create your HDR file. The camera will not create this HDR on its own. there are plenty of HDR tutorials on YouTube. Use a tripod ond a cable relaes when you are shooting in order to reduce movement in you images.
Mar 20, 2009 | Nikon D80 Digital Camera
Bracketing won't work
Did you take the pictures in automatic mode or are you taking them in Program or Manual mode? Try switching modes. it sounds like you are looking to get different exposures for a given scene, so I'm guessing you are looking to take better photographs. Let me know about your other shooting variables that are set on the camera and I'll let you know.
Nov 27, 2008 | Nikon D80 Digital Camera with 18-135mm...
Auto bracketing on a nikon d50
no. if you want more than 3, you will have to manually bracket those beyond the initial three. alternately, you can get a reading for settings then change to manual and continually adjust your aperture setting from whatever under exposure level you want to whatever over exposure level you want.
mark
Dec 09, 2007 | Nikon D50 Digital Camera
Group portraits with fluorescent lighting
Appature settings are never precise because they constantly need to be adjusted to suit the individual lighting conditions, in other words it is impossible to make a blanket statement for the best fstop and shutter speed to use for florescent lighting since that would depend on the size of the room ambient light the number of florescent lights and the distance to the target. As a rule of thumb these cameras have reasonably good light sensors so setting them to auto and pressing the button halfway should show you a display of the recommended fstop and shutter settings. I would recommend then bracketing from these settings. Bracketing is the process of taking several shots while varying the exposure settings to "passthrough" the optimal settings. Usually if you have a good idea what exposure will work a three step bracket is all that is required.
Example (based on outdoor exposure):
Optimal settings show shutter at 500 fstop at 16
Bracket picture 1:
shutter 250 fstop 16
Picture 2:
Shutter 500 fstop 16
Picture 3:
Shutter 1000 fstop 16
There is also a handy rule of thumb for exposure settings
Note that this also changes based on type of film
See the following chart for iso 400 film fstop of 16:
Bright sunlight: shutter 1/2000 th or just 2000
Partly cloudy: about 1/500th or 500
Overcast:1/125th or 125
Medium source (open window on a sunny day): 60
Inside light: 30
Low light: 15 up to 1"
night: varying
Hope that helps
Mar 06, 2007 | Canon EOS Rebel K2 35mm SLR Camera
CD400 Exposure Bracketing BUG!!!
What is the aperture and shutter speed when you take the bracketed exposure? The reason I ask is if the camera is at it's limit in shutter speed or aperture you could get a no change exposure.
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Sequential shooting modes
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: - Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. - High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. - AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. - Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Fuji FinePix S3100 Digital Camera Logo
41 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
